FM reception
Old Jun 26, 2002 | 05:35 PM
chuck91's Avatar
chuck91
Cruising
Default FM reception
seems that fm reception on my 1991 is bad. Seems to be worse since I installed new amps
Old Jun 27, 2002 | 01:04 AM
JCAIRE2's Avatar
JCAIRE2
Default Re: FM reception (chuck91)
found something that mentioned a radio relay last night. Unfortunately I forget where I saw that. Could have been here or another site, do a search and see what you find. I will be tackling this problem myself soon.
J
Old Jun 27, 2002 | 09:14 AM
91-Z07Coupe's Avatar
91-Z07Coupe
Default Re: FM reception (JCAIRE2)
There was some discussion on this several months ago. Seems Chevy went out for bid on a new radio receiver supplier in 1990 and the lowest bidder that won supplied substandard receivers for 1990 and 1991. Chevy went back to the original supplier in 1992. So you can either have your receiver rebuilt (the part behind the glove box), or find one from a 92 and swap them out.
Old Jun 27, 2002 | 09:26 AM
chuck91's Avatar
chuck91
Cruising
Default Re: FM reception (91-Z07Coupe)
thanks for the update, I'm new to all of this. [IMG][/IMG] :seeya
Old Jun 27, 2002 | 12:49 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
There's a groung kit that can be put on the surrounding area under the antenna. It help's. Not alot but it help's http://www.zr1.net/bulletins/339008.jpg
To FM reception
