Help With Win Aldl
I have some readings that may help me figure the Code 33 out.
Latest Values:
MAF: 18.60 g/s
MAT 103.F
TPS .65V
Max Values:
Maf 101.44 g/s
BPW: 7.80
TPS" 1.92 V
RPM: 2925
IAC: 241
O2: .906V
Thanks for any help I can get..
So i have to wait till tommorow morning to test it again. Its a cold/ hot problem.
The above values are from when it had a code 33 when it was cold.
New Maf, both relays relays, repaired the harness wires to relays and fuel pump relay, set tps. has the newer Prom 8109 in it.
I just need to get a base line for a normal car with winaldl so i know what to look for when it does it.
Also the green wire to the maf has 5v unplugged, 0v plugged and when started 3.5v..
maybe when i get the log files someone can help me figure out whats going on.
Update:
Checked all the grounds goind to relays and maf they are .1 ohm also the green data wire to B12 on the ECM is .1 ohm. Followed the FSM it shows its all fine..
Donnie
