1990 Rear Radio Speakers
Old 07-08-2013, 02:07 PM
tombobbitt
tombobbitt's Avatar
Default 1990 Rear Radio Speakers
I have a 1990 and the rear amps are shot. The radio store says I need to replace the radio with a built-in amp but non or the radios are the same size as my original. They are half the size and the lower part has a kit that installs and it looks awful.
Any one know someone who has amps for the rear of a 1990 Corvette Conv?
Old 07-08-2013, 02:27 PM
bangbgC6
bangbgC6's Avatar
Doctor Dons is the best for the BOSE system and he's out of Huntsville TX
www.doctordons.com
Old 07-08-2013, 03:20 PM
Churchkey
Churchkey's Avatar
90 radio size is double din.
Check @ Crutchfield, many styles to choose from.
Old 07-08-2013, 04:04 PM
AirForceOne!
AirForceOne!'s Avatar
I have an Alpine Double Din in my 90 and it fits perfectly!
[IMG][/IMG]
Old 07-08-2013, 07:54 PM
ozzyrulesme
ozzyrulesme's Avatar
I have a kenwood in my 90 with the install kit that has a cubby hole under the radio and I like it. Place for the phone and I-pod.
Old 07-08-2013, 08:17 PM
DRidgeway
DRidgeway's Avatar
Kenwood DDN770HD fits like a glove and has every feature you can imagine.
Old 07-08-2013, 10:59 PM
csthews
csthews's Avatar
If you want to stay original and save money, there are a few posts here on repairing the amps. You might want to give that a try.
Old 07-09-2013, 04:49 AM
65Z01
65Z01's Avatar
Cruise-In II Veteran
You might check with Vette2Vette for a price on used amps or perhaps the entire "box" (enclosure, amp & speaker).
Old 07-09-2013, 12:48 PM
bangbgC6
bangbgC6's Avatar
Do you have any interior pix that show it in daylight?
Old 07-09-2013, 12:50 PM
davewhtt
davewhtt's Avatar
Thats what i just finished doing. Found the how to here on our forum and the capacitors at radio shack. Easy enough job and now i have 4 working speakers. Good for the time being but i will be getting something new down the road. Took about 30 mins per amp and cost under 30$ for all the parts.
Old 07-09-2013, 03:32 PM
DRidgeway
DRidgeway's Avatar
My car is scheduled to be here Friday and Ill post pics of it then.
Wade
Old 07-11-2013, 06:04 PM
tombobbitt
tombobbitt's Avatar
To Davehtt. I cannot find anything on the forum about fixing my amps in the rear of my 90 conv. Where did you find this?
To others that have a Kenwood in their car. Does it have its' own amplifier? Did you have to rewire the radio to work?
Old 07-11-2013, 06:18 PM
csthews
csthews's Avatar
http://forums.corvetteforum.com/c4-g...pair-pics.html
Here is a post on repairing the amp for a '88. I think the repair is similar for the '92.
If you install an aftermarket head unit, you can buy a wiring harness from Crutchfield that will allow you to use your existing speakers. However, there is also another device you will have to buy and install that prevents the really loud and annyoying "POP" from the speakers whenever you turn on the stereo.
In lieu of that, you can buy speakers that fit the enclosures and wire them directly to the head unit using the speaker outputs. You don't have to add an amp, but if you want high quality sound, the amp is the way to go. Most head units will have both speaker and pre-amp outputs. So you can make that decision after you purchase the unit. I went the "no amp" route with plans to eventually install amps and subs.
Old 07-11-2013, 07:48 PM
dlrx
dlrx's Avatar
www.doctordons.com
I had my 1996 Bose head unit rebuilt by Dr Dons with the aux input conversion of the cassette. Took a week to ship to them, fix, and to receive back to Iowa...excellent work by them, I highly recommend their work if you want to stay stock.
Old 07-11-2013, 08:00 PM
tombobbitt
tombobbitt's Avatar
Thanks for the responses.
Tom
Old 07-12-2013, 09:50 AM
tombobbitt
tombobbitt's Avatar
miker2: Do you still have the 2 amps? Who rebuilt them? Will they work in the rear of my 1990 conv?
Old 07-12-2013, 02:19 PM
tombobbitt
tombobbitt's Avatar
miker2: Thank you for the response. Do you know the amount of amps they put out? I need to know that they will work in the 1990 conv. in the rear. It appears that you have a coupe.
To 1990 Rear Radio Speakers
Quick Reply: 1990 Rear Radio Speakers
