? on DBW
Old Jul 15, 2013 | 05:59 PM
aDigitalPhantom's Avatar
aDigitalPhantom
Default ? on DBW
A servo motor is an entirely different story. The servo motor is actually an assembly of four things: a normal DC motor, a gear reduction unit, a position-sensing device (usually a potentiometer—a volume control ****), and a control circuit.
From a C5 is the throttle position sensor on a DBC throttle body the same as a DBW throttle body? if not is it possible to install the TPS from a DBW TB on a DBC TB.
On another one of my run away ideas I am am thinking of trying to use an asr motor with a dbw setup to control a cable throttle. And am looking for information on DBW.
Old Jul 16, 2013 | 04:31 AM
vetteoz's Avatar
vetteoz
Originally Posted by chevyowner
From a C5 is the throttle position sensor on a DBC throttle body the same as a DBW throttle body?.
Suspect you will get a better answer in the C5 depot given no C4 ever came with DBW
Old Jul 16, 2013 | 07:35 AM
aDigitalPhantom
Probably, but the asr is off a c4, I also was not sure where to post this.
Old Jul 17, 2013 | 12:48 PM
aDigitalPhantom
Well it looks like this forum will only do something if a kit is made for it....guess I will ask elsewhere IF I am willing to share the results of what I find either way.
Old Jul 17, 2013 | 01:05 PM
ch@0s's Avatar
ch@0s
What exactly are you doing? LS swap?
Old Jul 17, 2013 | 07:28 PM
aDigitalPhantom
Yes, I am considering using drive by wire only for adding cruise control.
I am also considering using a ms3 instead of the factory computer for the engine.
Old Jul 17, 2013 | 07:42 PM
ch@0s's Avatar
ch@0s
I went with a a cable for simplicity and used a Camaro ECM and harness.. are you familiar with this thread?
http://forums.corvetteforum.com/c4-g...x-swaps-8.html
Ask in there and you will get a better answer. If you are going to keep the 700 or have a manual the MS3 sounds like a great idea. Have you seen this one yet?
Old Jul 17, 2013 | 08:00 PM
aDigitalPhantom
The last major hold up I have for the swap is.
Deciding between buying computer tuning kit and wiring harness for the ls computer.
I don't have enough of a stock harness to modify one for this.
Or getting a ms3x and making a harness for that.
Old Jul 17, 2013 | 08:31 PM
ch@0s's Avatar
ch@0s
There are too many options. I'm not a tuner but I am good with wiring so I took the wiring harness and modified it for my needs. The tuning was done locally and it runs great.
What is your set up/plans so far and what have you bought?
Old Jul 17, 2013 | 09:06 PM
aDigitalPhantom
well the list of parts I still need are
fuel pump
wiring harness
MAF
Air intake
Tuning software
possible parts
fuel injectors
fuel rails
To ? on DBW
