Over heating problem
Old Jul 16, 2013 | 02:00 PM
nailer007's Avatar
nailer007
Default Over heating problem
My heater core failed so I bypass it now my 94 over heats. Any body have idea what I did wrong
Old Jul 16, 2013 | 02:10 PM
lt4obsesses's Avatar
lt4obsesses
Probably nothing. As long as the flow of the coolant isn't interupted.
Now, it could be a few things. First question is what temps are you getting to? and is the coolant boiling?
I ask this because many new LT1 owners look at the analoge gauge and freak out when it appears to be near the overheat mark. The gauge to look at is the digital display on the instrument cluster. This is the more accurate. If it is 230-231 at it's highest point, you're okay, this is normal for the LT1 in stop and go traffic.
If it's going higher, then there is trouble. My first suggestion, in seeing that you had recently done repairs to the system, especially a leak, is that you have air in the system. Do a search and you will see this is a pretty simple proceedure to fix.
Old Jul 16, 2013 | 02:15 PM
csthews's Avatar
csthews
If you noticed an increase in temperature immediately after bypassing the heater core, it is possible that you have air in the system.
Old Jul 16, 2013 | 02:16 PM
nailer007's Avatar
nailer007
With the air off she gets 260 but cools a bit at higher speeds, one time at a light she stalled
nailer007's Avatar
nailer007
How do I clear the air out
Old Jul 16, 2013 | 03:17 PM
csthews's Avatar
csthews
Sounds like an air flow problem. Have you checked to make sure that both of your fans are coming on and that the front of the radiator isn't full of trash?
Old Jul 16, 2013 | 06:51 PM
vetteoz's Avatar
vetteoz
Google works
http://forums.corvetteforum.com/c4-t...on-an-lt1.html
http://forums.corvetteforum.com/c4-g...ml?forum_id=34
http://forums.corvetteforum.com/c4-t...ng-system.html
http://forums.corvetteforum.com/c4-t...procedure.html
http://www.corvetteactioncenter.com/...em-95-lt1.html
Unlikely seeing the only thing he played with was the core and he makes no mention of any previous cooling problem
As previously stated , more likely to still have air in the system
Old Jul 16, 2013 | 07:31 PM
nailer007's Avatar
nailer007
This is great info! Thank you,, I'll burp my baby this has to be the problem before the bypass she drove cool.
I'll let you know how it turns out, thanks again.
Originally Posted by vetteoz
Google works
To Over heating problem
