Windshield cleaning help
Old Jun 27, 2002 | 09:39 PM
TALMADGE's Avatar
TALMADGE
Default Windshield cleaning help
Help, What is the best cleaner to use on the inside windows. I cleaned them with windex and a couple of days later you can see spear marks. I used 409 and cleaned them once followed by fine steel wool, but that didnt work either. Any suggestions would help me see a brighter road.
Old Jun 27, 2002 | 10:05 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: Windshield cleaning help (TALMADGE)
I use a "tint safe" foam on all inside windows. I think the trick is to use a clean and dry papertowel as thorough final wipe. I've never had problems with streaking.
Old Jun 27, 2002 | 10:28 PM
JHammer's Avatar
JHammer
Zaino makes a glass polish that works great! :yesnod:
Old Jun 27, 2002 | 10:40 PM
HG's Avatar
HG
Me too, I would rather clean the muffler than the inside of the windshield. What a PITA ( Pain in the A** )
Old Jun 28, 2002 | 12:41 AM
Glasman66's Avatar
Glasman66
Go to Home Depot and grab Zep glass and surface cleaner (in an aeresol can) use a lint free towel like brawny. That shoud clean it up nice.
Trust me I've cleaned an as# load of glass. :crazy:
Old Jun 28, 2002 | 12:48 AM
morphious's Avatar
morphious
Default Re: Windshield cleaning help (Glasman66)
I have used everything, and the best I found was water and a nice terry towel. No streaks, no swirls. My 2 cents. :D :cheers:
Old Jun 28, 2002 | 01:43 AM
poppy's Avatar
poppy
Cruise-In III Veteran
With a name like Glasman66 I'm with you. :yesnod:
Old Jun 28, 2002 | 06:44 AM
93 ragtop's Avatar
93 ragtop
Are you using Armol all on the dash? Some of the protectants will evaporate off of the dash and smear on the inside of the window.
Old Jun 28, 2002 | 10:15 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Stoners glass cleaner. You can find it at Pep Boys.
Old Jun 28, 2002 | 12:30 PM
Tims94's Avatar
Tims94
Default Re: Windshield cleaning help (joecaver)
The Zep from Home Depot is really good. Also, Walmart carries a glass cleaner in the automotive section made by Gunk. I like all of the Foam type cleaners. Also, use newpaper to wipe off the glass. Newpapers are good to clean b/c it wont streak as bad. Try it!
Old Jun 28, 2002 | 06:55 PM
John Row's Avatar
John Row
I was given some Armoral glass wipes. These put a coating on the glass to make rain water streak off. I noticed that follow-on cleanings get a lot cleaner than before.
Old Jun 28, 2002 | 07:14 PM
Kdrhpe's Avatar
Kdrhpe
Default Re: Windshield cleaning help (Tims94)
...use newpaper to wipe off the glass. Newpapers are good to clean b/c it wont streak as bad. Try it!
Old Jun 28, 2002 | 09:14 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Actually it's called "Invisible Glass" and is made by Stoners..I get it at Pep boys also...I use it with 100% cotton towels..no paper towels :nono: ..when your done cleaning them wipe with a fresh dry towel and voila..it's all good..
p.s. this assumes you do NOT have tinted windows !
[Modified by golfboy1, 8:16 PM 6/28/2002]
Old Jun 29, 2002 | 01:29 AM
jfb's Avatar
jfb
I wipe my glass dry with a chamois and do not get streaking.
Old Jun 29, 2002 | 03:46 AM
robblk90's Avatar
robblk90
Default Re: Windshield cleaning help (Kdrhpe)
Old Jun 29, 2002 | 10:42 AM
carguru's Avatar
carguru
Default Re: Windshield cleaning help (golfboy1)
:yesnod: Invisible Glass works great. I use it religiously. Good alternative is Eagle 1 20/20 Glass cleaner.
Old Jun 29, 2002 | 04:02 PM
GDP's Avatar
GDP
I don't know if I'd be comfortable using a product with a name like Stoners on it... maybe it's just because I'm still in high school. :conehead
Old Jun 29, 2002 | 04:52 PM
Glasman66's Avatar
Glasman66
Forgot about the newspaper thing
Old Jun 30, 2002 | 01:35 AM
Nifty C6's Avatar
Nifty C6
I like GM Glass Cleaner. You should be able to buy it at any GM dealer. It doesn't streak like Windex. NEVER use steel wool, fine or otherwise on glass. It will scratch it. If you have accidentally sprayed Armorall on the glass, you can remove it with a solution of 1 part ammonia, 1 part Ivory or Dawn dishwashing detergent (without bleach), and 5 parts water. (This formula was given to me by Armorall.) You're also better off with paper towels, like Bounty, than with newspapers. They used newspaper for cleaning glass years ago when soluble inks were used. The ink would soak up the dirt. Today, newspaper inks are insoluble.
To Windshield cleaning help
