Shocks
Old Jul 30, 2013 | 01:30 PM
  #41
ptziems's Avatar
ptziems
I see a lot of different shocks listed on Eckler's, but how do I know if I have Z51 suspension or not. I do have the adjustable suspension, is that the same thing?
Old Jul 31, 2013 | 07:31 PM
  #42
craneman61!'s Avatar
craneman61!
did you install the gas adjust or not?
Old Aug 1, 2013 | 12:57 AM
  #43
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Check your RPO list under the cargo compartment door
Old Aug 1, 2013 | 04:35 PM
  #44
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by speedycat3
I agree...
If you want to test this theory, take one rear shock off from your car, and drive it to about 50 mph, and you will experience the wheel hop that otherwise is been suppresed by the shock.... But seriously, you dont need to test that yourself, just look on the highway and eventually you will see a pick up truck with shocks worn out enough so that you can see the wheel hop. That is what cause tire cupping, and enough shake to cause you to loose some grip on the highway too.
Worn out or no shocks mean the tire...which is a spring...can set up undamped oscillations. This doesn't mean the suspension will automatically move with each revolution of the wheel when you have good shocks on the car.
Something has to deflect the wheel to cause the suspension to move. Reasonably balanced and round tires on a perfectly flat surface would not result in suspension movement. Unfortunately, we don't drive on perfectly flat surfaces.
That's what causes suspension deflections, not tire rotation.
That's my opinion, and I'm sticking to it.
