Just finished my project
This project started because I needed a battery and when I went to replace that I freaked out and saw a little bit of rust so I wanted to sand and repaint the entire frame with Por 15, after that it ballooned out to suspension and brake upgrades real quick. here are some before and after pictures and some build pics.
this is a Before Picture
this is an After Picture
front end tear down
removal of front upper control arm bushings
front suspension put together
Front brake comparison stock vs CTSV brembo
Stock rotor VS C6 Z06 rotor
CTS V Brembo
2013 stock Grandsport wheels
2013 Grand Sport wheels painted 2013 Corvette Spiral Gray metallic
Exotic Muscle Coil Overs
Polished shiny suspension and brake bits
getting the alignment done
they stick out too far.
But I like the GS wheels better , flares wont be enough !!
Checkout OE wheels ,they got some nice wheels
How the rear brackets work out, any rubbing issues?
there really aren't any special brackets they bolted up to the sock spindle just needed to space them out with washers about a 1/4" and because the bolts for the calipers were smaller than the stock ones I had to put a stainless steel insert in the spindle to take up the extra room.
