Another beginner question-Changing shocks
Old Jul 25, 2013 | 07:32 AM
Djtjak's Avatar
Djtjak
Default Another beginner question-Changing shocks
I plan to change the shocks on my 1992. Looks pretty straight forward. When you change shocks where do you place the jack? Front ? Rear?Where do you place the jack stands? Front? Rear?
Dennis
Old Jul 25, 2013 | 09:14 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
See if this link helps
http://forums.corvetteforum.com/c4-t...-94-c-4-a.html
Old Jul 25, 2013 | 09:04 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Look along the rocker panels, you'll find the jacking points
For jack stand location find a substantial frame point
Its been a while since I've had mine to jack up
IIRC in the rear there is a flat place near where the frame widens out. Its hard to explain when you look under there you'll see it. In the front it depends on what I'm doing, lots of options. When you lift the front you'll see the options.
Good luck
Old Jul 27, 2013 | 08:33 AM
Djtjak's Avatar
Djtjak
Thanks for the advice, it was very helpful
Dennis
Old Jul 27, 2013 | 11:39 AM
lt4obsesses's Avatar
lt4obsesses
Don't forget you need a floor jack to hold the rear knuckle at ride height when changing the rears. And be carefull with the bolts on the frame at the rear, there are welded nuts inside the frame, you don't want to break one loose. (don't ask me how I know)
Old Jul 27, 2013 | 01:04 PM
Djtjak's Avatar
Djtjak
OK ,you have me scared on the rear shocks
I assume you broke one of the nuts off, what was the fix?
Any suggestions on what I should do to insure I don't break one off?
Dennis
PS i do have a floor jack and two jack stands
Old Jul 27, 2013 | 03:06 PM
lt4obsesses
Dennis
Just go slow should be fine. I just got in a hurry and I guess there was a little rust and the nut snapped free from the weld. At the time I just bolted the old shock back up tight. Went to a chevy dealer as I didn't really have time or the tools. But the solution if this happens is to drill about an 1 1/2 hole in the frame to get a wrench on the nut to remove and replace, then either weld or jb weld a plate over the hole and paint. But don't worry, this is the kind of thing that only happens to me, so you'll be fine.
Old Jul 27, 2013 | 03:39 PM
Djtjak's Avatar
Djtjak
Just bought a can of PB Blaster, i plan to use plenty of it
Dennis
To Another beginner question-Changing shocks
