Front spoiler replacement?
http://www.corvettemods.com/Corvette...ts_p_5938.html
BMAD type air scoops can easily be made from sheet aluminium or even tin if desired, then painted.
As far as what I did to the three piece unit... I riveted the three pieces together where they join to add rigidity and continuity to the front spoiler. I also found it necessary to rivet the brake cooling hoses onto the brake ducts as they would not stay with just a tie-wraps provided in the kit. Overall it is a nice kit with some minor modifications. It really needs cooling hose backing plates at the spindles to really make this a truly complete kit. DRM sells the backing plate for cooling hoses to the brakes.
Also - you might want to put some screen over the air inlet area to prevent frogs, leaves, birds and small children from being sucked up into the cooling system.
