Question regarding A/C system
Old Jul 30, 2013 | 07:44 PM
inviS4ble's Avatar
inviS4ble
Cruising
Default Question regarding A/C system
The A/C in my 92 vert blows cool air, but not cold
While digging around to see if it's been upgraded to R134A (it has), I noticed that the hose leading into the evap core is loose:
I assume this could impact my cooling
Is this something that can be fixed, or do I need a new core with attached hose? Can I just reseal the junction between the hose and the core?
TIA...
Old Jul 30, 2013 | 09:44 PM
csthews's Avatar
csthews
Do you feel air blowing out of the box with the blower on? If not, I wouldn't think that it has a significant impact on cooling. You may just be low on freon. Have you checked your system pressures? Also, does you compressor cycle frequently which could be an indication of low pressure?
Old Aug 1, 2013 | 08:26 AM
inviS4ble's Avatar
inviS4ble
Cruising
No air was coming out of that gap, so I guess that's not an issue
The freon looked a little low, so I emptied a 20oz can into it, and it seems to be cooler...I'll check the next time I'm out in the heat
Thanks!
To Question regarding A/C system
