C4 frame/ underbody question
Old Aug 6, 2013 | 07:51 PM
lonesomeloser's Avatar
lonesomeloser
Default C4 frame/ underbody question
While working under my car, I have noticed some light corrosion along the frame rails. Was the frame a bare aluminum, or was it painted/protected from the factory? I tried looking for pictures but had no luck. I am thinking of removing the corrosion and spraying some black or gray epoxy.
Old Aug 6, 2013 | 08:23 PM
383vett's Avatar
383vett
The C4 has a steel frame. It wasn't until the C6Z06 that Corvettes had an aluminum frame.
Old Aug 6, 2013 | 08:27 PM
vetteoz's Avatar
vetteoz
lonesomeloser
So it was painted. Do you know what color?
Old Aug 6, 2013 | 09:45 PM
WW7's Avatar
WW7
Mauve I believe......At least thats the color in the picture above ....
Just kidding, mine looks like it's black, I have also had the halo panels off and the metel under there looks black also....WW
Old Aug 6, 2013 | 10:01 PM
lonesomeloser
Ok, thanks. I have some black epoxy that's begging to be used.
Old Aug 7, 2013 | 02:19 AM
Jerry Roubos's Avatar
Jerry Roubos
'Collector's Originality Guide' Corvette C4 1984-1996
page136
The uniframe was built of high strength steel that was zinc- coated or galvanized before it was primed and then painted black.
It ( The C4) was one of the most rust-resistant cars of the twentieth century.
Old Aug 7, 2013 | 09:55 AM
WW7's Avatar
WW7
page136
I didn't know that , I guess GM learned there lesson on the C3.. Alot of C3 Corvettes have rusted frames so bad they can't be repaired. I have seen C3 frames that were rusted completely through......WW
To C4 frame/ underbody question
