Suspension Question.
Old Aug 11, 2013 | 12:26 AM
NuckinFutz93's Avatar
NuckinFutz93
Default Suspension Question.
What if anything suspension wise should/could use off a Z07 wreck?
My car is a base FE1 suspension, if that info helps.
Old Aug 11, 2013 | 12:59 AM
vetteoz's Avatar
vetteoz
Originally Posted by NuckinFutz93
What if anything suspension wise should/could use off a Z07 wreck?.
Depends how you want to drive / like your ride?
The Z07 springs /swaybars are stiffer than your FE1 springs so the car will handle better but have a stiffer ride which some don't like.
ZO7 also got the FX3 shocks but you would need all the wiring / electronics installed to make them work in a base car
Steering rack may be the faster (less turns ) version
Old Aug 11, 2013 | 02:05 AM
NuckinFutz93
Stiff doesn't bother me. I'm not going to mess with the FX3 stuff, plus I doubt its good anyway. I already robbed the springs and sway bars, just wanted to see if I should grab anything else.
Thanks for the response!
Old Aug 11, 2013 | 03:37 AM
1991Z07's Avatar
1991Z07
I second grabbing the steering rack...along with the cooler.
Old Aug 11, 2013 | 11:11 AM
Boxcar's Avatar
Boxcar
Life Starts at 120 mph
NCM Lifetime Member
I would suggest looking at the links for the sway bars, to ensure they are the correct ones. There might be a difference in length.
To Suspension Question.
