Engine block drain?
Old Aug 13, 2013 | 09:54 AM
Allentown Ernie's Avatar
Allentown Ernie
Default Engine block drain?
Hey fellas, is there a pedcock drain valve on a 90 L-98 engine block
if so, where ?
Old Aug 13, 2013 | 10:13 AM
GKK's Avatar
GKK
No, petcock...
Remove the Knock sensor located underneath the passenger side head to drain the engine block.
Old Aug 13, 2013 | 10:41 AM
John A. Marker's Avatar
John A. Marker
The block essentially has two sections. Removing the knock sensor on the passenger side will drain this section. There is a pipe plug on the drivers side in about the same position as the knock sensor on the other side. Remove this to drain this half of the block. The 90 might have a knock sensor on both sides of the block.....not sure for this year.
When you remove the sensor of the plug, the coolant may not flow out. There is often a thin layer of rust that covers the inside lower part of the block. Just use a screw driver and poke it into the hole.....be prepared for a flood of coolant.
Old Aug 13, 2013 | 12:05 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Aug 13, 2013 | 09:49 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Here is the amount of coolant I got out of my block last week. This is how much I got out of both the passenger and driver's side well after the radiator was drained.
Old Aug 14, 2013 | 01:50 AM
Cliff Harris's Avatar
Cliff Harris
I recently drained my block and got about 3 - 4 quarts out of each side. The two sides are not connected together internally so you have to drain both sides.
Cars with the oil cooler option will have a hose fitting screwed into the driver's side instead of a plug. It's easiest to just remove the hose.
If you buy some parts from a hardware store you can flush your cooling system with a garden hose:
To Engine block drain?
