Harmonic Balancer Question
Old Aug 15, 2013 | 10:57 PM
mazdaverx7's Avatar
mazdaverx7
Default Harmonic Balancer Question
installing the harmonic balancer on my 84's engine and it stopped sliding over the crankshaft. I don't think its deep enough.. here's a pic:
if it needs to be deeper, how much deeper on the crank should it go? how does one go about getting it to slide onto the crankshaft farther?
Old Aug 15, 2013 | 11:01 PM
Frizlefrak's Avatar
Frizlefrak
Here's what you need....
Old Aug 15, 2013 | 11:04 PM
mazdaverx7's Avatar
mazdaverx7
I will have to find a center section with the same thread pitch as my harmonic balancer bolt.. then it looks to be a spacer, a nut and a washer.. and I would turn the nut while holding the end of the threaded center section? where does the washer go?
Old Aug 15, 2013 | 11:07 PM
Frizlefrak's Avatar
Frizlefrak
The tool is SBC specific. It threads into the crank snout, and the washer goes between the bearing and the balancer. Works like a champ. I had the balancer back on my old 84 in under a minute and fully seated.
Old Aug 15, 2013 | 11:08 PM
mazdaverx7's Avatar
mazdaverx7
guess i'll have to locate one tomorrow. how far does the balancer seat onto the crank?
Old Aug 15, 2013 | 11:13 PM
Frizlefrak's Avatar
Frizlefrak
Any parts store should have it. Bottom the balancer out completely.
Old Aug 15, 2013 | 11:14 PM
mazdaverx7's Avatar
mazdaverx7
awesome, thank you very much!! i'll be sure to head to the parts store tomorrow and pick one up. gotta make sure the job is done correctly!
Old Aug 15, 2013 | 11:38 PM
Frizlefrak's Avatar
Frizlefrak
This tool also helps avoid putting excess stress on the threads in the crank. Stripping those is the LAST thing you want to do!
Old Aug 16, 2013 | 04:19 AM
Cliff Harris's Avatar
Cliff Harris
It's possible that the harmonic balancer is hitting the key for the timing chain gear. Had that happen to me. I had to do a little tapping on the gear key to get it down and out of the way. Don't know why it was a problem since the harmonic balancer was on there more than 15 years...
Old Aug 16, 2013 | 07:42 AM
mazdaverx7's Avatar
mazdaverx7
i considered that. i may remove the balancer and see if there are any burrs that i missed on the key for either the lower chain gear or the balancer. once i have the proper tool install should go easily. i did ensure that the lower timing gear was seated all the way onto the crankshaft.
Old Aug 16, 2013 | 09:03 AM
Just BOB's Avatar
Just BOB
You should be able to feel it when the end of the balancer bottoms out against the cam gear. even when bottomed out, the end of the crank is recessed down in the bore of the balancer, so don't be concerned that it is no where close to flush. If you pull the balancer yo can measure the depth from the face of the timing cover seal to the face of the cam gear, then mark the same distance on the balancer nose with a piece of masking tape. when the edge of tape is flush with the seal you will either be seated or close enough that torquing the crank bolt will pull it up the rest of the way. (as suggested, check that cam key. If you chamfer the entry of the key slot in the balancer a bit things square up a lot easier)
Old Aug 16, 2013 | 11:37 AM
MrWillys's Avatar
MrWillys
It is a 7/16 national fine thread. I've always made my own, or used longer bolts to get it started. It looks like it needs to go further too me.
Old Aug 16, 2013 | 04:39 PM
mazdaverx7's Avatar
mazdaverx7
after removing the balancer and reinspecting it, it appears as though the balancer shaft is bottoming out on the timing gear. i did ensure that the timing gear was fully seated on the crankshaft. here's what the timing marks look like. is this normal??:
Old Aug 16, 2013 | 11:48 PM
mazdaverx7's Avatar
mazdaverx7
after reinstalling the balancer and installing the water pump, it seems as though it was seated properly the entire time and i was worrying for nothing. the balancer and the water pump pulley appear to line up perfectly:
Old Aug 16, 2013 | 11:53 PM
Frizlefrak's Avatar
Frizlefrak
It's fine.
Old Aug 17, 2013 | 12:49 AM
Cliff Harris
I recently did a timing chain replacement and had the same issue. The harmonic balancer just didn't seem to be on the crank far enough. I used the "pulley alignment" criterion to decide it was OK. I've been driving it a couple of weeks and the belt hasn't flown off so I think I'm good.
Old Aug 17, 2013 | 08:43 AM
yd328's Avatar
yd328
Dave, your only problem was that you are working with nice shiney clean parts. If the old grime was still on there you would have known the balancer was on completely. Nice work.
Gary
To Harmonic Balancer Question
