Things just got ugly.. Codes.
po131 02 signal low bank (sensor)
po134 low o2s activity bank (sensor)
po138 o2 signal high bank (sensor)
po171 fuel system too lean bank 1
po300 engine misfire detected
po400 EGR recirculation flow fault
po420 catalyst efficiency low bank 1
po430 catalyst efficiency low bank 2
po441 evap system incorrect/ no purge flow
p1380 abs dtc detect/ rough road/ bad data
p1381 cylinder misfire- abs/pcm serial data
p1441 evap system flow during non-purge
If anyone has had any of these issues or codes per say, gimme a brief idea where to start haha. I know some of these codes aren't engine related, but the engine ones are the ones i'm focusing on right now. I noticed the issue about a week ago while driving. I came to a stoplight and the idle went rough. It also smells wretched. like.. terrible. Gassy Id imagine. And going uphill seems to be a struggle for her once under heavier acceleration. sounds like it wants to stall out when its at a stop or about to go from a greenlight. I recently replaced her BCM a few weeks ago, only to have these issues come out of nowhere. literally. thanks
