Help with RPO Codes
Old Jul 1, 2002 | 06:38 PM
Huckzilla's Avatar
Huckzilla
Default Help with RPO Codes
I copied down all of the RPO codes listed in my car and was able to identify all except the following:
BGR, E52, E92, NA5, V73
If anyone is able to identify these, I'd greatly appreciate a reply with your results :)
Old Jul 1, 2002 | 07:40 PM
VetteNoob's Avatar
VetteNoob
Default Re: Help with RPO Codes (fast90)
Check out this site.
http://www.corvetteactioncenter.com/specs/1990.html
Old Jul 1, 2002 | 07:55 PM
95AquaC4's Avatar
95AquaC4
Go to my website.(link in sig.) Site index "RPO Codes." EVERY code for C4's is there!!
Old Jul 2, 2002 | 12:17 AM
Huckzilla's Avatar
Huckzilla
Default Re: Help with RPO Codes (95AquaC4)
Thanks guys....I was able to identify the rest of these codes with your help. Either of you (or anyone else for that matter) know what E5Z - Delete Speedometer Adaptor and E9Z - Delete Speedometer Key means?
Thanks again! :cheers:
Old Jul 2, 2002 | 08:48 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
The E5Z and E9Z delete codes mean that the mechanical speedometer drives were not installed. You should have a D9A "Speedometer Sensor Arm" installed instead. This is the electronic speedometer drive. The 1990 C-4 speedometer is driven electronicaly not thru a cable.
To Help with RPO Codes
