Catalytic converter question
Old Sep 8, 2013 | 08:44 PM
nivensid's Avatar
nivensid
Default Catalytic converter question
I have a 1987 standard coupe. My converter was rattling a lot today when I started to go on a Sunday afternoon drive. Sounded like a bunch of ball bearings in a tin can. The car was running like crap at the time, lucky to get it up to 35 MPH. 2 hours later it is running good with no issues.
I started looking for replacement converters, the 87 models look like they bolt on one end and weld on the other. I looked under the car, from what I can see without jacking it up is the converter bolts on both ends? Did the factory one bolt on each end or bolt on one end and weld on the other?
Old Sep 8, 2013 | 09:50 PM
SeeFourSix's Avatar
SeeFourSix
My 91 is weld on - bolt on.
Old Sep 8, 2013 | 10:11 PM
84wuzmy1st's Avatar
84wuzmy1st
Yes, they started doing this in 86 i believe.
Old Sep 8, 2013 | 10:20 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
You have three cats on an 87. The front two precats are welded, the rear one is clamped on the front (3") , and bolted on the back, unless it has been replaced.
Old Sep 9, 2013 | 01:20 AM
Cliff Harris's Avatar
Cliff Harris
My '86 is like this.
To Catalytic converter question
