I owned a 93 about 10 years ago and loved it. I finally found a 95 and purchased it. It needs alot of cosmetic love where it sat out in the sun constantly. This one has the decals on the side- are these factory? If so any idea where to get new ones?
A heat gun or a hair blow-dryer will aid in the removal of the decal. I don't know that I'd recommend attempting the removal with a buffer. Some of those decals are tough.
If you know an automotive painter or body man they would likely have one of these that could help also but a good hot hair blow-dryer should do well:
If you wanted to buy it's a 3M 07501 adhesive removal tool but you need a "roloc" disc holder to use it, that's a 07500 and can be used for the "roloc" gasket and abrasive removal discs also. Might be a good buy or you might already have if you do your own services and maintenance.
