Ground location
Old Sep 14, 2013 | 10:04 AM
Pete919's Avatar
Pete919
Default Ground location
I've read multiple posts that state there is a ground point above the oil filter that has multiple grounds going to it. I can't see it, only one I see is the one on the bellhousing with a strap to the frame which I'm replacing. Other than that and the visible ones on the frame, is there another one I'm missing? I'm trying to clean them all. Thanks.
94 lt1 6 spd
Old Sep 14, 2013 | 10:34 AM
Cliff Harris's Avatar
Cliff Harris
Earlier years had the ground on the side of the block. I think that was L98 engines.
My '86 has no grounds on the bellhousing. Only the tach filter is mounted there. I do know that there were at least some there in '89.
