valve cover gaskets
Sep 14, 2013 | 08:00 PM
valve cover gaskets
have to replace 26 yr old gaskets. what`s the best to use? i don`t know whats there now. i have the aluminum heads if that makes a difference. that pipe on right side, i guess EGR pipe, will it be a problem to get off?
Sep 15, 2013 | 09:13 AM
use the rubber ones, you can re use them too, generally you dont have to use any adhesive on them as long as the rocker covers are flat
Sep 15, 2013 | 09:24 AM
how about that EGR pipe? don`t look like its gonna want to come off.
Sep 15, 2013 | 09:41 AM
Soak the bolts you only have to loosen the ones on the intake you remove the ones on exhaust then gently twist the EGR pipe out of the way. That is how I do mine
Sep 15, 2013 | 10:32 AM
Finalist 2020 C4 of the Year - Modified
I prefer the blue Fel-Pro.
Sep 15, 2013 | 11:44 AM
Sep 15, 2013 | 11:52 AM
Me 3 .. I cheat, I spray a hair of trim adhesive then stick it to the Valve cover so I don't have to worry about it slipping.
Sep 15, 2013 | 06:00 PM
Quote:
Originally Posted by
blackbear bob
+1 for Fel-pro
+2
Sep 15, 2013 | 06:11 PM
Sep 15, 2013 | 07:52 PM
Frizlefrak
Fel Pro rubber
/end thread
Sep 16, 2013 | 01:45 AM
Unbolt the EGR tube from the intake manifold. It is flexible and you can bend it out of the way without detaching it from the exhaust manifold.
Sep 16, 2013 | 09:36 AM
I actually use a rubber on the left side (so the tall cover clears the wiper motor) and a felpro blue on the right side, both work well,
the biggest problem i found is the original magnesium rocker covers seem to leak no matter what you do, using solid alloy aftermarket covers cured the problem.
Sep 16, 2013 | 11:27 AM
Frizlefrak
Fel Pro rubber
Sep 16, 2013 | 05:12 PM
magnesium valve covers? look like stamped steel, centerbolts to me.
Sep 16, 2013 | 07:27 PM
The stock covers are magnesium
