running hot.. fan running fine.. changed out the thermostat, no difference.. old thermostat checked out ok.. no movement in the radiator as should be at operating temp.. keeps running hot according to temp gauge.. pulled the water pump.. looks good.. impellers are fine. no blockage..no blockage in radiator, hoses. what am I missing ??
any suggestions would be great.. thanks
has never went over @190 F before this.. should there not be movement of the water in the radiator when the thermostat opens (195) ? bought used.. no owners manual.. sorry
If your high temp went only to 212f, then you absolutly have coolant circulating. As stated, 230 temps are not unusual. My guess the reason your operating temp went up is you collected garbage on the front side of your radiator.
my 88 has digital dash .. used to show up as @ 190 on the temp .. the fan kicks in .. and turns fine.. but I have not seen the water move in the radiator since I first noticed the temp going up .. just driving it steadily climbs up as I'm driving never have had this happen
Cooling is not rocket science........ all that is needed is air flow and coolant flow..... block one or both, and you will overheat.
The only adverse condition you see is the lack of coolant flow. The only items that control flow are the tstat, pump, hoses. If the tstat is not opening, you have a problem. If the pump is not moving coolant, you have a problem. If a hose is collapsed, you have a problem.
seabright.. that is my thinking.. just never had it run this hot,..
and the normal operating temp might be higher..
I only let it get to 212 it was still climbing.. had just never had it go that high except then the radiator got a huge hole in it. and had to replace it..
thanks for all the help/suggestions.. real witch taking the water pump off..
if none of these make a difference.. one person suggested it might be trying to blow head gasket or some other "engine" problem.. still has me stumped on the water movement.. .. again.. thanks.
212 is cold in traffic. ECM controls the fan on at 228 and 230 is normal sitting in a traffic jam in Southern California. If your fans were coming on earlier then someone changed the tune to do so. I believe the aux fan switch is 238, but I replaced mine before measuring temp with a lower temp switch.
If you want the fan to come on at a lower temp find a tuner and have them change it on the chip. Mine is now set to come on at 210 and off at 185.
..... Check for trash in between the radiator and A/C condenser ... you have to open up the top half of the shroud to get at it ... I go in there at least once a year and I'm always surprised at what I find .....
If your looking for coolant flow while at idle speed, you won't see movement. Have someone increase the RPM's while you eyeball the coolant in the neck. Take it for a short drive and see how hot it gets. If you get up to 240 shut it down. My guess is, based on the info you have supplied, you will not over heat. Who ever suggested a head gasket problem is wrong.
Yeah, right...... the pump doesn't move at idle..... the coolant just
remains motionless, and absorbs heat.
I guess I should have been more precise. At idle, there is little coolant movement and can go un-noticed looking down the neck of the radiator. Add a few RPM's and it will show.
