ecm removal
Old Sep 30, 2013 | 06:51 PM
chillin-n-killen's Avatar
chillin-n-killen
Default ecm removal
are there any videos or tech help on removal of the ecm on a 1986 coupe 350 tpi....or maybe a way to test a ecm ?? tnx in advance
Old Sep 30, 2013 | 07:11 PM
JackDidley's Avatar
JackDidley
Remove the black plastic panel under the passenger side of the dash. Get a ratchet, extension and a 10 mm socket and take out 2 bolts. Pull the ecm down and out. There is a wasp nest of wires in the way of the ecm but you can work it out around them.
Old Sep 30, 2013 | 08:42 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
The ECM is very easy to pull out once you remove those two bolts holding it in. It just "unplugs" from the wiring harness leading to it.
Old Sep 30, 2013 | 08:57 PM
WW7's Avatar
WW7
Don't forget to disconnect the battery........WW
Old Oct 1, 2013 | 08:24 PM
chillin-n-killen
Default ecm
tnx to all the replys on my questions about my ecm removal...great site
To ecm removal
