Ignition control module or distributer?
The engine is supposedly A ok
The electrician I hired has gone through every single wire we've replaced everything even the computer. yet the gremlin still lives.
We have done EVERYTHING except for 2 more things.
The ignition control module or the distributor.
He basically said if this isn't it, he's hit a brick wall and there is nothing else he can do.
My symptoms are this. The car runs GREAT when it is cold. It runs good for about 5 min and then degrades until about 20 min when it just completely goes to hell. It is not firing the injectors correctly and I am getting jerked forward with power and then it bogs down throughout the RPM range. By 20 min the car is only running on 4 cylinders. The electrician said the computer is shutting down the passenger side fuel bank. But remember this only happens when the engine gets hot.
Now through my research I've discovered the ICM usually shows itself when the car is hot, however most times it shows itself by not allowing the car to start or it shuts it down. So its an on or off type thing.
The distributor I would feel shouldn't be affected by temperature?
However I heard current is affected by heat so i really don't know.
What do you guys think? This problem is electrical.
Is it the ignition control module or Electric control module??
at 5 psi... the car can't run can it?
tested the fuel pressure and it is ok
Kevova remember I ran these injectors on a stock ecm for 4 years with no problems.
There is a disruption in the circuit that controls firing the injectors.
Seeing that the distributor sends the signal to the computer and the computers send the signal to the injectors, a bad coil pack could be messing with the computer and the computer shutting off the injectors.
I just told you two posts up I had the pressure checked and it came out ok.
