New here with a problem
Old Oct 6, 2013 | 01:57 PM
Richard Padgett's Avatar
Richard Padgett
Default New here with a problem
86 4/3 stopped working and smoke coming up thru the console..just got this car wondering if I smoked the overdrive..lol,.can I drive it without the overdrive without causing further damage?? is it fixable without replacing it...thanks
Old Oct 7, 2013 | 08:00 AM
Kevova's Avatar
Kevova
I think you need to find out burned or melted under the console and decide. Cars on fire is not fun. The O/D may not be cause of smoke.
Old Oct 7, 2013 | 08:25 AM
WW7's Avatar
WW7
I had smoke coming out the bottom of my dash and it was the Heat, A/C controls burning up.......WW
Old Oct 7, 2013 | 08:52 AM
Goldcylon's Avatar
Goldcylon
Check for a mouse nest. Might have been up inside chewing on the wires
Old Oct 7, 2013 | 11:33 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Do all four of the forward gears and the reverse gear still function normally? What were you doing (speeding?) when you noticed the smoke? Did you have it in overdrive, and if so, was that functioning normally?
Old Oct 7, 2013 | 05:28 PM
Richard Padgett
found out at the same time this happened it was power steering fluid spewing all over the place so I found the smoke problem,it shifts fine now,got er fixed..thanks
Old Oct 7, 2013 | 09:43 PM
Jerry Roubos's Avatar
Jerry Roubos
Default Welcome
Welcome, glad that you solved the problem, enjoy your C4.
Old Oct 8, 2013 | 09:50 AM
FOURSPEEDVETTE
Old Oct 8, 2013 | 12:16 PM
Richard Padgett
VERY Cool...glad to be here
To New here with a problem
