I am finding harder to believe daily how neglected this poor car was. Anyway, 93 vert battery died. Hear is what I have observed. Driving the battery light and door lights flicker. With the car off you periodically hear what sounds like a bad fan blower sound. The climate control is off. Any ideas where to freaking look?
Common problem.
Usually a faulty blower control module (BCM ) , a solid state "relay" controlled by the HVAC head unit that supplies power direct from the batt to the blower motor
However you may want to check the fuse 1st.
Just a general thought, check your various electrical connections. A poor or bad connection can cause all kinds of strange thing to happen.
It's cheap and just takes some time.
Did you replace the battery or just recharge the battery?
Question: What is the actual name of the button that depresses when your door is closed that shuts the interior lights? I think one or both of those might be a problem as well.
