Won't Start
Old Oct 24, 2013 | 04:02 PM
jserio's Avatar
jserio
O.C.
Default Won't Start solved
Here we go. Got home last night car running fine, parked it. shut off, done for the night. This morning went out, Got in, went to start, Cranked great, coughed 1/4 of a second and nothing. Same thing several times. Ideas?
Old Oct 24, 2013 | 05:06 PM
Kevova's Avatar
Kevova
Out of gas? You might give a little more info.
Old Oct 24, 2013 | 05:40 PM
jserio's Avatar
jserio
O.C.
Full Tank.
Not much more to offer. I went to start it. It acts as though it's ready to start. Puffs then nothing. Just happened this morning. Ran great last night.
Old Oct 24, 2013 | 05:49 PM
CREWZIN's Avatar
CREWZIN
Looks like a C5 in your Avatar, is that the car that won't start?
Old Oct 24, 2013 | 07:05 PM
jserio's Avatar
jserio
O.C.
Sorry I have to update that. It's a 93.
Old Oct 24, 2013 | 07:47 PM
flier32's Avatar
flier32
If you can't provide helpful information to a fellow Vette owner, please don't post anything.
Old Oct 24, 2013 | 09:35 PM
csthews's Avatar
csthews
Start by pulling the codes and posting them.
Old Oct 24, 2013 | 10:06 PM
higgyburners's Avatar
higgyburners
I believe in the Beer Fairy
St. Jude Donor '15,'19
good advice I would start by checking the codes
no need for negative BS if you cant help don't post.
Old Oct 25, 2013 | 12:08 AM
jserio's Avatar
jserio
O.C.
I will try and get the codes on Saturday. I will update then.. Sorry I have not offered more.
Old Oct 25, 2013 | 12:18 AM
DjDragon's Avatar
DjDragon
2nd Gear
Default want start
Check your wiring that comes from battery,that cost me a fuel pump I did not need!
Old Oct 25, 2013 | 08:55 AM
Kevova's Avatar
Kevova
codes may not point to cause. To test basics you need a few things : a spark tester GM's version is a ST-125, A noid (blinker) light for the car or injector you have, Fuel pressure gauge kit (not all cars have schrader valve type connection), a 12 volt test light and a Digital Volt Ohm Meter. These tools can be found at auto parts stores, sears. Should not be that expensive, some auto parts stores have loaner programs. It sounds like alot, but other than noid light (since there a drifferent injector connectors) you can use this stuff to diagnose lots different systems and cars. FSM, Alldata, or atleast a chilton / haynes type book for information
Old Oct 25, 2013 | 10:30 AM
mazdaverx7's Avatar
mazdaverx7
i would first start by checking to see if there is spark going to the optispark unit. attach a plug wire (or use the existing wire) to the coil and insert a spark plug into the plug wire and crank the engine. if it has spark, move onto the next phase.
test for spark coming out of the opti by pulling one of the plug wires from a plug and inserting a spare spark plug into it, grounding it, and cranking the engine, looking for spark. if you have spark, its time to test the airflow meter, and start looking into the fuel system and ecu.
Old Oct 25, 2013 | 11:09 AM
jserio's Avatar
jserio
O.C.
very good. I'll post results.
Old Oct 27, 2013 | 03:23 PM
jserio's Avatar
jserio
O.C.
Haven't got codes yet but the car started. Idled very rough. When I went to give it gas cut right out. Fuel pump maybe?
Old Oct 27, 2013 | 06:48 PM
vetteoz's Avatar
vetteoz
Originally Posted by jserio
Fuel pump maybe?
Only the fuel pressure test suggested above will tell you ..............
Old Oct 27, 2013 | 11:15 PM
jserio's Avatar
jserio
O.C.
Next
Old Oct 28, 2013 | 12:08 AM
NuckinFutz93's Avatar
NuckinFutz93
I hate to be the one to say it, but it sounds like the opti.
To Won't Start
Old Oct 28, 2013 | 12:47 AM
vetteoz's Avatar
vetteoz
http://www.mainstreamtopics.com/foru...rt-diagnostic/
Old Oct 28, 2013 | 07:52 AM
AirForceOne!'s Avatar
AirForceOne!
Opti or fuel injectors or both!
Old Oct 28, 2013 | 10:12 AM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Not likely the opti and injectors would both go bad at the same time.
