ride help
Old Oct 29, 2013 | 11:00 AM
19774x4's Avatar
19774x4
Default ride help
how to raze the rear end on a 91 vette coupe
Old Oct 29, 2013 | 11:39 AM
94z07fx3's Avatar
94z07fx3
Increase ride height by tightening the spring bolts. (the bolts, one per side that go through the composite spring) If the spring is worn out then replace.
A PO may have installed longer bolts specifically to lower ride height.
Old Oct 29, 2013 | 06:17 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Full Definition of RAZE:
1
a) archaic : erase
b) to scrape, cut, or shave off [as in: I want to raze the big Azz back of my C5. )
2
to destroy to the ground : demolish (eg. raze an old building)
Now, if you want to raise it, that's another topic.
Old Oct 30, 2013 | 01:17 AM
Cliff Harris's Avatar
Cliff Harris
Check the rear spring to make sure you don't have a problem. They can crack, especially if they are exposed to heat or nasty chemicals.
You might try measuring the length of the bolts so we can compare to ours to see if they are non-stock.
Old Oct 30, 2013 | 01:45 AM
lt4obsesses's Avatar
lt4obsesses
New shocks? Seiously, if those are the originals, they really need to be replaced. When I did mine it raised the rear end considerably.
1
a) archaic : erase
2
Beat me to it.
Old Oct 30, 2013 | 10:54 AM
19774x4's Avatar
19774x4
Beat me to it.
so sorry about the spillding,
Old Oct 30, 2013 | 11:01 AM
19774x4's Avatar
19774x4
1
a) archaic : erase
2
so sorry about the speilling, give me a break you raise it your way and i will raze it my way,ha ha
Old Oct 30, 2013 | 07:13 PM
92ragtop's Avatar
92ragtop
All in good fun!
Old Oct 30, 2013 | 11:42 PM
lt4obsesses
Spellnz overraited anywayz.
Just try the new shocks, it's your easiest and cheapest possible solution to a saggin rear end. (on a Corvette) Then go from there.
Old Oct 31, 2013 | 11:06 AM
19774x4's Avatar
19774x4
thanks for the input, i will try shocks first and go from there
Old Oct 31, 2013 | 11:21 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Quick check Stock bolts around 9", Lowering bolts 10"- 12"
Old Oct 31, 2013 | 04:28 PM
19774x4's Avatar
19774x4
thanks for the info
Old Oct 31, 2013 | 04:40 PM
383vett's Avatar
383vett
Howza pare of newz shoks gunna raze the rare enz more then 1 qurter of na inch? Theyz gazz filed when newz, but theire not lika airy shoks.
Old Oct 31, 2013 | 05:38 PM
19774x4's Avatar
19774x4
i know but i need new ones anyway, they are 15 yrs old
Old Oct 31, 2013 | 05:43 PM
lt4obsesses
Exactly why I suggested it. When I replaced mine, which turned out to be bottomed out, as might be yours, while I didn't measure, I would say the chassis lifted somewhere between 1/2" to a full inch.
Now, I'm thinking about lowering bolts
Old Nov 1, 2013 | 10:40 AM
19774x4's Avatar
19774x4
Default red vette
tell me about your car, how did you get that air. i have a 30 over 406 with 350th tran. 10to 1 pistons, brodux 11 heads mild street cam, brodox intake, and edelbrock 750 carb. this is a street car and weekend track car. 1/8 times 797 to 813 at 85mph. i want to get a little better than that out of the car any help out there, thanks, an old guy that wants to go a little faster
Old Nov 2, 2013 | 04:58 PM
19774x4's Avatar
19774x4
thanks for the info
To ride help
