Ideas
Old Nov 7, 2013 | 08:21 PM
spro2395's Avatar
spro2395
Default Ideas
It looks like
a previous owner of my 85 put a floor jack under
the left rear seat mounting bolt.
I would say it's pushed up about an inch or so making the seat a little crooked.
How can I push it back down to straiten the seat?
Old Nov 7, 2013 | 08:29 PM
don hall's Avatar
don hall
If the bolt is just 'pushed up', remove the seat.......
pound the bolt back down using a block of wood and a
heavy hammer. Screw a nut on the bolt to protect the
threads.
Old Nov 7, 2013 | 08:31 PM
NuckinFutz93's Avatar
NuckinFutz93
If you have a roof to push from, you can use a port-a-power and a long board against the roof of a garage or something like that.
Old Nov 7, 2013 | 08:38 PM
spro2395's Avatar
spro2395
threads.
The section of the floor that's pushed up is 4 or 5 inches across.
Old Nov 7, 2013 | 08:47 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
threads.
Old Nov 7, 2013 | 09:25 PM
don hall's Avatar
don hall
With the seat track removed for complete access to the work area,
fabricate (cut) pieces of wood (2 - 2"x6"x5") high enough to clear
the stud....... drill out the center of the wood to allow the stud to fit through the wood...add a piece of flat metal plate (about 1/4" thick) over the hole in the wood and pound the wood as level as possible.
You will need a small sledge (not the rubber mallet suggested).
Old Nov 7, 2013 | 10:10 PM
Silver96ce's Avatar
Silver96ce
I had the same problem. Either the PO or his mechanic did the same thing on the passenger side. I agree with seabright and PLRX. I took out the seat and seat track. I then used a short piece of 2x4 that I laid wide side down between the seat bolts and then on end around the bolt area and used a hand sledge to beat it back down. It's not perfect yet as I ended up having to work on wife's car with starter and engine sludge problems - it is a Dodge with the famous "hand grenade" Mistubishi 2.7l engine. But the seat sits much better and I will revisit it in the spring with some custom cut pieces of wood and brass drifts.
Old Nov 9, 2013 | 07:59 AM
spro2395's Avatar
spro2395
Sounds like a plan. I need to find some steel now!
Old Nov 9, 2013 | 11:07 AM
don hall's Avatar
don hall
....I need to find some steel now!
Any piece of metal..... just something to pound on so you don't destroy the wood.
To Ideas
