Blinker Problem
Old Nov 9, 2013 | 04:49 PM
84wuzmy1st's Avatar
84wuzmy1st
Default Blinker Problem
Right blinker works correctly, Left blinker stays solid.
Lights work, Hazards blink.
Reading back in old threads it would seem that the left blinker staying on is due to a bad ground. I am not sure if this was a problem before i took out the rear tails for paint or not.
The wires going into the tail sockets look fine, bulbs are brand new though it also doesn't blink with the old bulbs I just replaced for long life bulbs... so I doubt it's the bulbs.
Should I take apart the sockets and actually look at the wiring inside? How do I test/look for the problem ground? Could the bad ground be behind the dash?
Any more information on fixing the issue would be greatly appreciated.
Old Nov 9, 2013 | 04:52 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Try this.........
http://kalecoauto.com/index.php?main...products_id=22
Old Nov 9, 2013 | 06:15 PM
84wuzmy1st's Avatar
84wuzmy1st
Oh lord... lol.
According to the FSM it sounds like it is most likely the signal switch. Ugh. Does not sound like fun to replace.
Old Nov 9, 2013 | 06:36 PM
hooked073's Avatar
hooked073
I have see a lot of people put bulbs in wrong or the wrong bulbs. Also are the fronts coming on
Old Nov 9, 2013 | 11:49 PM
Cliff Harris's Avatar
Cliff Harris
Echoing what hooked073 said, I have heard that if a bulb is put in backwards it can cause this symptom.
Old Nov 10, 2013 | 12:44 PM
cptwufennuxi's Avatar
cptwufennuxi
1st Gear
Default same problem
I have the same problem on my 87, left side stop blinking and just stays on, right side blinks slow, replaced bulbs no diffrence, anybody have any ideas for a fix,
Old Nov 10, 2013 | 07:06 PM
hooked073's Avatar
hooked073
Flasher
Old Nov 11, 2013 | 06:00 PM
84wuzmy1st's Avatar
84wuzmy1st
Fronts come on but also don't blink.
I am thinking signal switch in the steering column?
Old Nov 11, 2013 | 06:45 PM
hooked073's Avatar
hooked073
I highly doubt it is the turn single switch.
Old Nov 11, 2013 | 06:47 PM
hooked073's Avatar
hooked073
I would suggest pull all the bulbs you had out. Check to make sure they are the correct bulb for the locations. then reinstall.
Old Nov 11, 2013 | 07:48 PM
84wuzmy1st's Avatar
84wuzmy1st
I had already done that. I just ran up the road and grabbed a new turn flasher unit. Going to pop it in tomorrow and see if it fixes the problem.
Old Nov 12, 2013 | 02:21 AM
Cliff Harris
Turn on the 4 way flasher and see what results you get.
Old Nov 12, 2013 | 08:56 AM
84wuzmy1st's Avatar
84wuzmy1st
If you mean the hazards, they work, all lights flash.
Old Nov 12, 2013 | 09:21 AM
dukeallen's Avatar
dukeallen
Did you top off the blinker fluid?
Old Nov 12, 2013 | 07:20 PM
84wuzmy1st's Avatar
84wuzmy1st
WOOT. Blinker fixed. With help from the forums and pictures it wasn't too tough to find and replace the turn flasher module.
Old Nov 12, 2013 | 10:48 PM
John.87's Avatar
John.87
Happened to me also, turned out to be a bad ground. Glad you fixed it
Old Nov 13, 2013 | 02:35 PM
84wuzmy1st's Avatar
84wuzmy1st
Thanks, I believe that was the easiest thing I have done to the car thus far... lol
To Blinker Problem
