C4 Battery Replacement
Old Nov 10, 2013 | 10:16 AM
CCC C5's Avatar
CCC C5
Default C4 Battery Replacement
Is there any good step by step instructions out there to replace the battery in a 1995 C4? Mine is dead in the garage so I can not easily just take it to my local dealer. Thanks.
Old Nov 10, 2013 | 10:21 AM
Frizlefrak's Avatar
Frizlefrak
Disconnect terminals. Remove hold down. Loosen fender, slide battery out. Install is reverse.
Fender has a bolt between it and the rocker panel (10 mm if memory serves me correctly) that you can loosen by sliding an open end wrench in. You just have to loosen the fender enough to move it out of the way of the battery.
Taking the battery out is less than a 5 minute affair. Ensure key is off when you hook up new battery. Positive first, then negative.
Old Nov 10, 2013 | 11:01 AM
Greg Gore's Avatar
Greg Gore
You will have to remove the lower fender panel which requires several different tools; two sizes of torx bits, a 10mm open end wrench, and a ratchet with sockets and long extension (to reach the battery retaining bracket bolt at the bottom of the battery tray).
Old Nov 10, 2013 | 11:11 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Old Nov 10, 2013 | 11:13 AM
Klyde's Avatar
Klyde
When you open the hood and look at the battery location directly beside the battery is a small piece of fender that has the slots in it. You must remove several of the fender liner screws, a bolt on top of the piece and loosen a 10mm screw that is at the bottom between the fender piece and the lower rocker panel. Once out you can get to the battery hold down bracket bolts and slide the battery out through the fender opening. I once paid a Chevy dealer to replace my battery when it was in for an oil change. They billed me for an hour and a half labor. I ask why and they said they had to remove a support bracket and the ECM and its brackets just to get at it. They took it out through the top. I got out my owners manual and showed them how it was supposed to be done and refused to pay for more then a half hour labor. I have done it in less than twenty minutes several times before that and just thought since it was in for oil I would just have them do it. I have never used a dealer for any thing else since that day.
Old Nov 10, 2013 | 12:01 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
That lower 10mm bolt can be hard to spot and hard to get a wrench at. The gap is narrow, so if your 10mm wrench doesn't fit in there, get an old one and grind it narrower. As already said, you only have to loosen it, not remove it.
When re-installing the piece, make sure you adjust it so that your door gap is correct.
Old Nov 10, 2013 | 12:13 PM
Sassman's Avatar
Sassman
Follow that video posted earlier and you'll have no worries. Your '95 should accommodate a standard sized wrench for that lower 10mm bolt. I had no problems with my '94.
Old Nov 10, 2013 | 12:46 PM
Greg Gore's Avatar
Greg Gore
I watched about 1/2 of the video before being compelled to comment on a few errors. The bolt on top is 10mm, not 3/8 standard. You can gain enough room to get to the torx fasteners inside the wheel well by turning the wheels to the left. They are not allen or star, they are specific size "torx."
The negative battery cable is not in danger of grounding itself because it is ground. Positive is the one to be careful of.
Resume watching...
He did a good job cautioning against over-tightening the cable clamp bolts. Former GM Corvette engineer Gordon Killebrew says side terminal battery leaks at the posts are usually due to overtightening. He recommends 11 lb/ft torque and no more.
Video does a good job of guiding you through the steps. Thanks to the OP
Old Nov 10, 2013 | 03:06 PM
nicpete's Avatar
nicpete
follow the video and you will have no problem .
To C4 Battery Replacement
