hard brake pedal
Old Nov 11, 2013 | 06:45 PM
Tom Slick 88's Avatar
Tom Slick 88
Default hard brake pedal
Question, brake pedal very hard did vacuum check on booster at 18 you could watch the vacuum drop to 12 and then it would very slowly drop from there. What vacuum should the booster hold and for how long? Also brake fluid is very dark. Could there also be a problem with the ABS?
Thanks Tom Slick 88
Old Nov 11, 2013 | 06:47 PM
Tom Slick 88
Almost forgot C4 88
Old Nov 11, 2013 | 08:26 PM
CREWZIN's Avatar
CREWZIN
Sounds like it's time for a new brake booster. Replaced two on my 87 so far...and I do mean "new". More $$$'s than a re-built unit but it should last the rest of the cars life and you won't have to replace it again.
Old Nov 11, 2013 | 08:38 PM
l98tpi's Avatar
l98tpi
Max G’s
brake booster
Old Nov 11, 2013 | 09:47 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
Time to replace the power brake booster.
Old Nov 11, 2013 | 10:08 PM
JackDidley's Avatar
JackDidley
Old Nov 12, 2013 | 04:34 AM
91 corvette's Avatar
91 corvette
Did that this summer.
Old Nov 12, 2013 | 08:49 AM
Kevova's Avatar
Kevova
booster hose should have a large volume of vacuum ie...engine should stall or nearly stall if disconnected. May even whistle. If it doesn't port is restricted carbon build up, hose, or check valve. Either way it sounds like brake fluid needs flushed....dark/black fluid can hurt ABS.
Old Nov 12, 2013 | 06:10 PM
Tom Slick 88
Thanks to one and all. I figured it was the booster just wanted to get more input. I will flush the brake fluid and double check the vacuum just because I like to play
Tom Slick 88
To hard brake pedal
