Intermittent Clunk
Old Nov 17, 2013 | 12:38 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Default Intermittent Clunk
(1985, A4, very stock, 71k miles)
When I drive Lauren I sometimes (of course) hear a clunk. It'll get louder, than softer, go away, come back, etc. More data:
1) If you forced me to pick where it's coming from, I'd pick passenger's side front, but I'm not absolutely sure of that.
2) I hear it with the HVAC on or off.
3) I hear it more when I'm cruising or slowing down.
4) There's nothing obviously loose in the engine compartment.
Thoughts?
Old Nov 17, 2013 | 12:52 PM
AirForceOne!'s Avatar
AirForceOne!
Could be your tranny? I assume you have an automatic? When's the last time you had it serviced(flushed, new filter and gasket)?
Old Nov 17, 2013 | 01:02 PM
94z07fx3's Avatar
94z07fx3
Check caliper bracket bolts. Check the rubbery parts of the front suspension for metal on metal. Find an empty parking lot for a strip mall or warehouse where you can drive window down right next to the building to listen or better yet an observer that you can drive past.
Test for coasting in neutral vs in gear vs braking. Turn a few tight circles each way and see if it aggravates the clunk.
Old Nov 17, 2013 | 01:41 PM
hcbph's Avatar
hcbph
Default Other items
Don't forget to check the swaybar bushings and end. Just replaced them the other week in the van for similar reasons.
Old Nov 17, 2013 | 04:39 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Thanks, all! I'll check all of these ...
Old Nov 17, 2013 | 08:22 PM
DinoBob's Avatar
DinoBob
If it occurs when going over bumps, check your hood latch pins. One of mine was loose (drivers side) and it produced a horrible rattling/clunk sound over bumps. Just figured it out and fixed it today.
To Intermittent Clunk
