Downshift RPM
1800 rpm in 6th while cruising down the interstate isn't lugging.
But mashing the throttle in 6th gear @ 1800 rpm and trying to accelerate would be.
I've never seen one of those lights either, but it is obvious that it was intended to "train" people to drive for best fuel mileage.
Your excursions on I90 would be the only ones that you might see the need for a 6th gear selection.
But to answer your question, it probably was accurate.
But think about what it is actually telling you?
At that "instant" you were using more fuel to go up a hill than downhill.
Pay attention to what your foot is doing on the accelerator pedal in that same situation and it is easy to see.
The instant reading can be fun to play with, but that is about it.
The "average" reading on the other hand is much more useful, especially if you let it run without resetting it for awhile.
The more miles you accumulate after a reset, the more accurate it becomes.
You'll notice when you first reset it, the numbers will change (up or down) quite quickly.
But the more miles driven, the changes slow down.
Over the course of several hundred or thousand miles, it should be pretty close to what you would calculate using the manual way of calculating fuel mileage.
miles driven/fuel used = mpg
I do not find it mentioned in the FSM. Changing the rear end ratio would be way beyond the point of diminished return for me. Is there a disadvantage in shifting at the arrows suggestion? If I can get to where I need to go by burning a gallon of gas and shifting often that is better than using 1.01 gallons and staying in lower gears. Unless some day some mechanic says " What the heck did you do? Shift every time it told you to?" I'll just get the poly-brass left kneecap with the optional
grease zerk.
BTW, anything below 1000 rpm is pretty much idle. I am at about 1800 cruising at 70 in 6th gear, that is about as low as I get rpm wise. (3:45 rear gear)
As RollaMo-LT4 said already, there is no clear cut number for a decent driver. As an example; I'll go 900 RPM in 6th if I am cruising/coasting with my foot off the gas. If I'm at WOT, I generally don't want to be below 3500 RPM...but that is b/c I'm seeking max power -not b/c I'm worried about "Lugging". As long as the engine pulls smoothly w/o bucking, lurching, surging or vibrating, it's not "lugging".
nock or shudder. I would never open the throttle more than slightly at low RPM in a high gear without downshifting first. But is there any other car that can travel at near highway speed at near idle engine speed?
Where could one find instructions on resetting the VSS?
Lightweight + higher gearing (especially the 6-speed with its 0.50 overdrive) + high torque relatively low rpm V8 = low cruising rpm.
That is also the reason most Corvettes get much better fuel mileage than most people would believe.
