15 inch rim?
Old Nov 26, 2013 | 11:29 AM
smooth1990's Avatar
smooth1990
Default 15 inch rim?
Will a 15 inch rim bolt over the caliper and brakes? I want to put a set of 26 11.50 15 hoosiers on my 92 that a buddy has. They are off his 89 iroc camaro. Im hoping they will work but I dont know the offset and there is no stamping on the rims...
Old Nov 26, 2013 | 11:31 AM
NuckinFutz93's Avatar
NuckinFutz93
As long as you don't have the 13"J55 brakes. They fit over standard brakes.
Old Nov 26, 2013 | 11:39 AM
smooth1990's Avatar
smooth1990
As far as I know the difference in the J55 and standard brakes are only the front calipers and rotors. I believe the rear are the same on all the c4s?
Old Nov 26, 2013 | 11:44 AM
NuckinFutz93
OH. I miss understood. I thought you wanted them all around, now I see that you only run the rears for drag time.
Old Nov 26, 2013 | 12:06 PM
c4cruiser's Avatar
c4cruiser
Rear rotors are the same size for all C4's. The wheel offset will be the key. Using adapters may help as they would effectively move a wheel further outboard. Tire clearance in the wheelwell may be a concern if you use adapters.
But you should also check with your sanctioning body regarding the use of adapters.
Old Nov 26, 2013 | 12:50 PM
383vett's Avatar
383vett
I ran this setup with the Dana 44; 15X10 with 6 1/2" backspacing. 11.5X28X15 MT ET Drags. This picture is from a solid axle C4 but the wheel was the same from the irs.
Old Nov 26, 2013 | 10:23 PM
NuckinFutz93
3rd gen backspacing is 4.41" for 8" and about 5" for 10"
Old Nov 29, 2013 | 08:45 AM
smooth1990's Avatar
smooth1990
Dang 383, I love the look I f your car. Im guessing those are welds.
Old Nov 29, 2013 | 01:47 PM
383vett's Avatar
383vett
Thanks, You know your wheels.
To 15 inch rim?
By Michael S. Palmer | 2026-06-03 09:39:05
