BCM/Ignition Key
Old Dec 3, 2013 | 05:37 PM
Fishwagon's Avatar
Fishwagon
Cruising
Default BCM/Ignition Key
Hello all,
I've been doing a lot of electrical work on my 95 and just replaced the BCM. I was able to find a good used one.
Now, the key is not recognized. I realize the gizmo in the key is not being recognized by the security system anymore.
How do reprogram? From what I've gathered there are 15 different values and I may have to try one at a time until I hit the jackpot?
Thank you
Old Dec 3, 2013 | 06:14 PM
vetteoz's Avatar
vetteoz
Originally Posted by Fishwagon
How do reprogram?
You can't, the required resistance is locked into the BCM and can't be altered.
Correct
Either get a variable potentiometer and set it each of the key ohm resistance values
See
http://www.thirdgen.org/vats_passkey_system
and connect it to the VATS wiring under the column and try to start the car ( have to wait 4 minutes between each test )
or get a locksmith to use a key interrogator to find the correct value key you need
Old Dec 3, 2013 | 07:17 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Correct
See
Old Dec 3, 2013 | 07:42 PM
Fishwagon's Avatar
Fishwagon
Cruising
Thank you, makes sense.....appreciate the info very much.
Old Dec 4, 2013 | 02:13 AM
Cliff Harris's Avatar
Cliff Harris
I have heard that the later cars have a "learn" procedure that will read the key resistor and remember it.
I don't know if this applies to your car, but here is some info related to this:
http://my.cardone.com/techdocs/pt%2077-0011.pdf
Old Dec 4, 2013 | 05:59 AM
vetteoz's Avatar
vetteoz
Only on a new out of the box CCM when it is 1st installed
As I already stated the value is locked in on a used unit
http://forums.corvetteforum.com/c4-t...ce-values.html
http://forums.corvetteforum.com/c4-t...o-new-ccm.html
Old Dec 4, 2013 | 06:19 AM
Fishwagon's Avatar
Fishwagon
Cruising
Thank you very much for that, I'll try that first....appreciate it....
Old Dec 4, 2013 | 07:07 AM
toptechx6's Avatar
toptechx6
If you happen to be located in south Florida send me a PM, I have a VATS Interrogator.
Old Dec 4, 2013 | 07:30 AM
Fishwagon's Avatar
Fishwagon
Cruising
Thanks for the offer, but I'm in the Atlanta area. Appreciate it though....
Old Dec 5, 2013 | 02:36 AM
Cliff Harris
I saw a post somewhere (maybe here) from a guy who said there is an ADC (Analog to Digital Converter) in the CCM, ECM, PCM, whatever, that reads the key resistor and then converts that into a digital number that is then stored in non-volatile RAM. I thought he said you could reprogram the key resistor value using the method he spelled out, but that was probably 2 or 3 years ago so I don't really remember any details. Without a link to that post this is just vague babbling… ;-)
Old Dec 5, 2013 | 06:13 AM
vetteoz's Avatar
vetteoz
I saw a post somewhere from a guy who said there is an ADC (Analog to Digital Converter) in the CCM, ECM, PCM, whatever, that reads the key resistor and then converts that into a digital number that is then stored in non-volatile RAM. I thought he said you could reprogram the key resistor value using the method he spelled out,
Like anything electronic I am sure there are hacks to reprogram it but I recall that playing with the CCM is a bit of a touchy subject given it has the vehicle mileage recorded and could be subject to abuse
Old Dec 5, 2013 | 08:12 AM
hcbph's Avatar
hcbph
Default Vats
If you take your key to a GM dealer, they can read the value off the key. Once you have that you can either create your own bypass resister string or get a plug-in module from places like Ecklers that plug into the harness and the car reads that instead of the key. The upside is you don't need a resistor key only a key with the right teeth on it. The downside is the same so any key with the right teeth config can start the car. If you purchase the adapter I mentioned, you just unplug the wire from the ignition and plug this in so you don't cut any wiring in the process.
Old Dec 5, 2013 | 09:18 AM
Fishwagon's Avatar
Fishwagon
Cruising
Thank you all, appreciate it.....
Old Dec 5, 2013 | 02:42 PM
WVZR-1's Avatar
WVZR-1
The OP's situation is the reverse "so to speak" of what you mention. he needs the to use a VATS Interrogator of some sort to determine the "resistance value" of his BCM/CCM and the get a key done. The OP understands what's involved quite well it seems.
OP - I would approach a lock service about maybe renting his Interrogator for a couple of hours and then it's "your time" and not "his time" It seems you understand so a conversation with a shop might actually work for you. I have one also but I'm certainly not close.
Do you have any sort of relationship with a "parts guy" in a dealership? If he/she understood what your needs are they might also be willing to help you. It would require a "relationship" but it's not unheard of! You need 2 hours!
Your other situation is maybe nothing you're concerned with but down the road it could be an issue. The BCM/CCM you bought has the VIN & mileage from the car that it was removed from recorded and there's no way for you to "undo" that inexpensively. Is your intention to use it "short-term" and have yours repaired? What is the reason for the swap?
Old Dec 5, 2013 | 03:15 PM
Fishwagon's Avatar
Fishwagon
Cruising
Correct, this is a short term solution while other things are going on....I would purchase a new one if it does in fact solve the issue.
Appreciate it all...
Old Dec 7, 2013 | 03:50 AM
toptechx6's Avatar
toptechx6
Do a search on e-bay for j-35628, I just saw a VATS tester listed for $85 which is a great price, certainly less than I paid for mine. You can always sell it when you are done.
To BCM/Ignition Key
