Converting from Crossfire to something else
Old Dec 12, 2013 | 06:37 PM
edwardgwright's Avatar
edwardgwright
Default Converting from Crossfire to something else
Hi all,
I am thinking of converting from the crossfire injection and not really sure which way to go. Any input as to which way to go? I know that I will need a new intake and what every else that I decide to do but which is the easiest and simplest way?
Old Dec 12, 2013 | 07:19 PM
vetteoz's Avatar
vetteoz
Budget ?
Carb is the easiest /cheapest ,but you will get plenty of debate on here as to doing it
http://forums.corvetteforum.com/1565824290-post28.html
http://forums.corvetteforum.com/c4-t...t-to-carb.html
Any form of EFI will require a computer and wiring from later car
or aftermarket
Old Dec 12, 2013 | 10:16 PM
shawn 84&92's Avatar
shawn 84&92
I say enjoy the 84 for what it is or get a newer C4 with the injection system you like. I think you will be happier in the long run. Other than a carb, the cost seems really high for the performance gain.
Old Dec 12, 2013 | 11:37 PM
martymcfly's Avatar
martymcfly
Default What type system?
If you are thinking about efi, here are some comparisons that a guy put together. http://www.nastyz28.com/forum/showthread.php?t=240191
Old Dec 13, 2013 | 10:28 AM
Jay7199's Avatar
Jay7199
if your car is completely stock and you want to convert to a different fuel injection or even a carb for performance increase - don't waste your time.
I went through 3 different setups on my stock 84 untill i realized i was wasting time because of how poor the factory heads and cam are on the car.
If you are just looking to increase performance, I would say go get some headers and good flowing exhaust. a good running crossfire with some basic bolt ons will keep you entertained depending on how much power you are used too.
Old Dec 13, 2013 | 11:24 AM
CRUZNC4's Avatar
CRUZNC4
2022 C4 of the Year Finalist - Unmodified
Sell your 84 if your not happy with it for something you really like instead of swapping out the intake for something else and depreciate the value of the car. Besides NCRS and Bloomington Gold judges these cars.
Old Dec 13, 2013 | 11:27 AM
Jay7199's Avatar
Jay7199
Not really depreciating anything unless its a garage kept 84 with ~10k miles on it.
Old Dec 14, 2013 | 02:05 AM
whalepirot's Avatar
whalepirot
Exactly the advice I got in 1987; Guldstrand was right!
Got that T-shirt, plus; was happy for a short time.
Remember, an engine is a system and the L83 did well given the age. Just swapping in exhaust will not give it a great power increase, then it will get expen$ive (done that) via a hotter cam, 3.73 rear (huge mistake) on X-fire, stepping finally to the current, which is nasty fast, but - $ee part 1.
Old Jan 1, 2014 | 12:26 AM
GT2Race's Avatar
GT2Race
Default C4 Yo self
Hi all,
I say Stick with your Cross Fired setup .. I just finished rebuilding the top end of My 84 L83 xx-fire ... Porting the pajeezez out of the soft aluminum intakes can be done in one evening and add a 218/218 Cam from Lunati.. Wow
I went with a set of full length headers and the special Grind Lunati Cam
the cam is perfect for daily drivers and brings the 350 alive without you dumping any chance of decent gas milage
Let the xxx-fired Nay Sayers eat lunch and pack sand
Old Jan 1, 2014 | 07:51 AM
Paul Workman's Avatar
Paul Workman
Dominic (aka XfireZ51) has extensive data as result of his working with the L83. Porting the intake, cam(?) change, tune, injector change, etc netted him mid-low 13s; would run with and even beat some LT1 cars on the 1/4 mile track (he says).
It may very well be a better choice to simply trade up to what you want, than do extensive mods on a Corvette (or any car, for that matter). But, talk to Dominic to another L83 modder's input. Then you have options.
Note: XfireZ51 visits here, but has since moved to modding ZR-1s. You may find him on the CF ZR-1 page or the ZR-1 Registry under the Community tab; "members". Dom is a bit of a perfectionist when it comes to tuning, and I'd touch bases with him too if seeking L83 modding info.
Old Jan 1, 2014 | 09:43 PM
qws's Avatar
qws
If your thinking switching to a multiport type of injection its not that hard to do with the right ecm. No changing of the main wiring harness is needed
Old Jan 1, 2014 | 10:25 PM
GT2Race's Avatar
GT2Race
Default Good advise
I say listen to this fellows advise 100%
You can get your car to run into the 13's no problem
Making the best out the cross fire is worth everything
You will be stoked and being the under dog always has it's rewards
Please dont Frankenstein you ride
fronzy
Old Jan 2, 2014 | 04:50 PM
corvettenorway's Avatar
corvettenorway
stock ecm ????
Old Jan 2, 2014 | 09:29 PM
GT2Race's Avatar
GT2Race
Default New / not
Originally Posted by corvettenorway
stock ecm ????
Stock dizzy / stock ecm / halls butt and yes those are things that you can upgrade while your enjoying your ride
Old Jan 3, 2014 | 11:02 AM
corvettenorway
mine runs great now ! but going to put new heads,new cam,long tube headers this winter
Old Jan 3, 2014 | 08:33 PM
GT2Race's Avatar
GT2Race
Default We are ditto
Ditto dude , Found a set of 882 heads ( steelies ) for 100 bucks on Craigs list ..Im assumming you have the 662 ones
found a set set of full length headers used for 200 - craigs list
added some noisy gears and a ton of polish and chrome .. the fun stuff
bought this 14 inch carbide aluminum Burr and some wax
of course I blew through the intake in a few spots .. took it to my local guy and he fixed me up perfectly
cant wait to run an 1/8th mile here in irwin dale or Fontana speedway
Fronzy
Old Jan 3, 2014 | 09:14 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That is some odd advice. A cam is expen$ive? They're like $100 bucks. Exhaust can make a big diff, porting the intake (which I guess you didn't do) makes a HUGE diff, and I agree the money spent on gears was a waste.
OP; I went low 13's with my CFI (Trans Am) for ~$1400.00. That included a change to a 400 SB, as I was starting w/only a 305 and that terrible F-body exhaust.
Used 400; $400
Summit Cam; $90
Summit RR's; $150
Used headers; $100
SLP SS cat back; $300
Ported intake; $40 for gaskets?
Injectors; $90
Electric fan $35 ('Vette already has an electric fan)
JY "Underdrive" pullies; $30
Walbro 255 LPH fuel pump; ? -can't remember
VRFPR; $40
...so it looks like I spent about $1350 or so to get low 13's/105ish out of it. Car ran like stock, got 24 mpg hwy...it was a great running car.
To Converting from Crossfire to something else
Old Jan 3, 2014 | 10:07 PM
GT2Race's Avatar
GT2Race
Default Guess I missed your point
Used 400; $400
Summit Cam; $90
Summit RR's; $150
Used headers; $100
Injectors; $90
VRFPR; $40
Guess you missed what I wrote ..
I specifically told you that I cut the intake myself in my shop in one with my own die grinder with my own compressor in one evening
What the heck are you looking .... frikin C4 vettes weighs 3500 to 3800 pounds plus you plus fuel
a few other cars that I own and work on myself and own them
Frankenstein Lives
Old Jan 3, 2014 | 10:17 PM
GT2Race's Avatar
GT2Race
Default Good luck
Used 400; $400
Summit Cam; $90
Summit RR's; $150
Used headers; $100
Injectors; $90
VRFPR; $40
Cams are 250 min with new lifters
Headers are 20 to 649 ( long tubes )
header gaskets are 50
upper end gasket sets are 150
every small thing adds horsepower.. if you did it all .. your talking still shy of 300
Do you realize that these early C$ vettes have been seriously de tuned .. starting with the compression
stock horsepower screamin out around 205
Old Jan 3, 2014 | 10:43 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Ahhh...no. The '84 Corvette (which is the one in question in this thread) weighs about 3200 lbs. I don't believe there was EVER a Corvette made that weighs 3800 lbs. Yikes. My wife's CTS-V weighs that...how could a 'Vette, also?? Reading for you....'84 specs
Negative. I'm sure that you CAN pay that much. DON'T NEED TO THOUGH!
Really? HOw do you figure that? That's not what Me, Dom, and others have seen.
I think we're all pretty well aware of the state of tune provided my the stock '84. Who's ?
