What to do next?
Here is an overview; thank you in advance for your suggestions:
This car was a "gift" with the home I just bought. The previous owner said he was driving home one day and the car just died so he parked it under a carport and just parked it several years ago.
The car starts (with little/low engine power) and after a very few seconds (5-6) starts to backfire through the intake and loses all power. this gets worse very quickly and the car will not idle
Here are the steps I have taken so far:
Before trying to start the car the first time:
drained/replaced gasoline
removed/replaced spark plugs and sprayed lubricant into the combustion chamber(s)
replaced the fuel filter
replaced the oil and filter
After starting the first time and having problems noted above these are the additional steps taken:
checked the firing order
double checked the firing order
triple checked the firing order
replaced the plug wires
replaced the dist cap
replaced the coil
replaced the rotor
checked the intake and hoses for an intake leak
So after haven taken all the steps above i came across an article on the forum and decided that the timing chain had gotten slack, jumped a tooth (although the car only has 77k miles) and decided to replace it. I took everything apart yesterday and low and behold the timing marks line up perfectly (ie this isnt the problem).
The question is where do I go from here? Do I tear down the top end of the motor and have the heads re-manufactured while i have everything apart (do you have a post on how to do that
? Is there something else I overlooked that I should have done first?Thanks much and happy holidays to all!
... Do all of the above , plus do an ohm check of all of the injectors ... with the electrical connector removed , test the two terminals in the injector ... you want to see around 16 ohms ... check cold and recheck hot ...........
I would also check for broken valve springs and do a compression check.
You might be able to find a used one here on the Forum in the Parts Wanted/For Sale section. The book will also help you diagnose future problems.
This eBay CD might be a good choice too. http://www.ebay.com/itm/1988-1989-1990-Chevrolet-Corvette-Service-Manual-CD-Repair-Shop-88-and-90-Wiring-/400613874220?pt=Motors_Manuals_Literature&hash=item5d46729a2c&vxp=mtr#ht_3138wt_936
Othewise, if you want to start replacing parts -
1. injectors;
2. fuel pump
3. fuel regulator
4. ICM
5. ECM
6. IAC
7. Oxygen sensor
8. etc. and on and on
Without the manuals it will get expensive quickly.
P.S. maybe someone with an '89 will read this and send you the diagnostic section dealing with this. Good Luck with the new car and its repair.
Good luck!
