on passenger side agianst the kick panel there is a vacumn control. is this the blend door control? it does not move no matter where the control switches are. it is in the up position, i am not getting any heat. there is a screw there, if i disconnect it will i get heat? don`t say get a FSM, i can`t afford one.
Cliff my 1991 C68 has a AUTO and a RECIRCULATE mode. Is this different from the pre-90
model cars ?
They completely redid the HVAC electronics in 1990. I don't know anything about it, except that they moved all the functionality from the HVAC control head to the HVAC programmer. Side note: I just found out that the FSM calls it the ECC -- Electronic Climate Control.
The blend door lever and cable is located on the heater core housing. It's easiest to get to it by taking off the passenger side kick panel (several 7mm screws).
I have seen a photograph somewhere but I couldn't find it to post to this thread.
