C4 Why So Many With Head Work?
Here's why
Stage 2
On a 383. Obviously it's working well for that guy
obviously an aftermarket lower manifold that's ported would help things considerably. But hell, I'd say the L98 TPI intake's workin plenty good there. There's guys out there with 406s and the TPI setup.
The first vid was on a stock chip too, and I think we can agree that car probably needed a tune to really sing.
Just a question of just how fast you really want to go
For me 11s would be utterly killer
For why there are so many with headwork, if I had to guess there's quite abit of that of years on most of our cars. Mine was what 23 years old when I got it, and had 130,000. To go with the age and miles the earlier heads and gaskets had serious issues from the factory, all the research I've done told me (after purchase of the car) that replacing a headgasket even on a then New C4 wasn't an uncommon practice under warranty.
I do agree that both are fine motors; nothing wrong w/either.
I know what an L98 is. I have owned 28 of them since 1990 and built probably 100 since then. Who said anything about changing heads?? You said changing an intake doesn't make it an L98. That is flat out wrong. TPI doesn't make the motor an L98. Come on now....that is flat out wrong and silly.
OMG I won't even retort on such a wrong post. I have an LS1 with AI LS6 heads,Fast intake etc. What motor is that now? ZZ4 is not even the same block as an L98. Look at the casting number. Changing heads/intake does not change the motor type. If I add LT4 heads/intake to an LT1 or TFS heads and convert an L98/LT1 to carb what does that make the motor???
Here's why
Hole-Shot's C4 Corvette, 383 Stroker TPI. Mods=Stage 1 - YouTube
Stage 2
Hole-Shot's C4 Corvette, 383 Stroker TPI. Mods=Stage 2. Vigilante Torque Convertor - YouTube
BINGO.
The stock prom is not as bad as people say with the stock cam either but the cars do run very rich due to emissions. Tell you guys what. I will look for an L98 car after the holidays. I will even get a convertable with tall gears with an automatic wityh some 100-130K on it-a good average car. I need a car like that at my Florida home anyway. I will show how easy it is to run low 14s and even high 13s without going into the motor on that heavy car at stock weight with stock wheels,gears etc. Plug choice,gap,shift points,cable adjustment and tune up is really important. The stock injectors are trash as is the stock fuel pressure,stock wires,stock coil and timing(which you can't adjust on an LT1). You can make a fun car on a budget or as a first timer.
I have a LM7 bored over to 5.7 with forged internals 241 heads and a LS6 intake in my C4. That is refereed to as an LSx and I imagine your would be too.
Aaron we are referring to the "stock TPI" Holeshot's vette is not stock TPI. The stock LTR set up sux.
I can't help but wonder what holeshot's vette would have done with the aftermarket base manifolds, and a tune myself.
For that matter what would he have done with a 400, or even a 406 in there
(guess who came into a good 400 block...for free)
Here is a good read/comparison. http://xtremecarzone.com.au/index.php?showtopic=386
PDF version for download..http://xtremecarzone.com.au/STORAGE/...akeOptions.pdf
So what is my LS1 now with LS6 heads and a fast intake? It is no longer an LS1???
What is an L98 with a miniram and tfs heads on it called? Its no longer an L98 since it doesn't have factory TPI on it????
I just built an LT1 with LT4 heads and intake and another with TFS heads and converted to carb. What are they now? Not an LT1?
I never said an L98 is not a SBC. Saying a new GM crate motor is the same as L98 is just flat out wrong. It is not by a long shot.
My goodness.....I am out of this thread before I laugh more and my head starts to hurt
GrandeDave- the L98 is a good dependable engine. As fore mentioned the head gaskets usually just need replaced in the higher mile car due to different exapansion rates between the AL head and Iron Block. No big deal. The L98 is easy and less expensive to repair in my experience.
LT engines start out with a head-start with: HP intake, more compression, reverse cooling, better exhaust, and better flowing heads. To improve the LTx platform for more power COULD require less money.
OTOH, for people doing complete builds, the difference isn't as stark. If you swap intakes, headers, cam, exhaust, heads, and stroke it (for both platforms), the "power potential" probably isn't much different. If so, it would come down to the reverse cooling design [providing a big more anti-knock protection].
Really power train issues can also be similar - in cost/challenge.
Personally, I'd say the LT motors have easier power -- as Cliff said.
From my perspective, the issue on power potential is a wide-open comment. Do you include turbos, superchargers, and any other possible POTENTIAL modification? What's the limit -- when you say potential?
I chose the 91 because I planned on modding. I like the late look and the support of the SBC. Not to say you cant mod a LT1 but that was my choice. I guess I don't have to worry about that now.
Make sure you let this guy know he doesn't need an intake (or TB)...
http://forums.corvetteforum.com/c4-t...4-upgrade.html
(I'm not going to tell him because I don't know what you can get out of a stock LT1 intake. Seen too many convert to the LT4 Edelbrock piece.
