Headlights on a 84
Old Dec 19, 2013 | 06:09 PM
edwardgwright's Avatar
edwardgwright
Default Headlights on a 84
My left headlight does not fully close by like 1/4 of a inch. Is their a way to adjust them so that they are fully closed and fully open.
Thanks all and Merry Christmas!
Old Dec 19, 2013 | 07:09 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
There is upper and lower stop screws on the front of the headlamp assembly. There are also four 10mm bolts under the lid for lid/hood adjustments.
Old Dec 19, 2013 | 07:49 PM
edwardgwright
it is not hitting that headlight set screw! it seems like it is the linkage is lose or something like that
Old Dec 19, 2013 | 09:16 PM
zr1fred's Avatar
zr1fred
Sounds like a broken gear in the motor then.
Old Dec 19, 2013 | 09:30 PM
hooked073's Avatar
hooked073
fred Iv only delt with a couple of 84 motors but is it possible the points are out of adj??
Old Dec 19, 2013 | 10:46 PM
zr1fred's Avatar
zr1fred
No, the points are made/broke by load on the motor forceing the shaft up or down against the points. It is possible to put the motor - headlamp linkage assembly in wrong, but I don't think that is the problem here unless he just rebuilt the motor.
Old Dec 20, 2013 | 12:39 AM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Is the motor still running when the door stops moving?? If not then it would appear that there is a bind in the pivot of the assembly, causing the armature to shift and open the points inside the motor.. If the motor keeps running you need to open the motor up and check the gears.. Here is a post by Cliff Harris on the process..
http://forums.corvetteforum.com/c4-t...placement.html
Old Dec 20, 2013 | 04:41 PM
edwardgwright
The headlight motors work it just leaves a small gap and I want it to close all the way!
Old Dec 20, 2013 | 05:54 PM
pezter22's Avatar
pezter22
This may not be the fix but my '84 had a similar problem. I replaced the gears and adjusted the mounting screws and it still was not looking like it was fully closed. I discovered the top headlight body cover (flat part) was not aligned correctly. I adjusted those screws and it finally looked correct.
Old Dec 20, 2013 | 09:09 PM
ccrazor's Avatar
ccrazor
Disconnect the motor and check for 12v between the grey and green wire of the connector.. If you have 12v then the motor should run until it hits the stop. If it is stopping before the stop then something is causing the motor to load enough to shift the armature enough to open the contacts in the motor..
Old Dec 20, 2013 | 09:12 PM
ccrazor's Avatar
ccrazor
This would be a solution if it was hitting the stops..
Old Dec 21, 2013 | 10:00 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Something is jambing the mechanism. Do you see any interferrence in the headlight door assembly hitting the hood, with the hood raised? If not, something is jambing the gears.
To Headlights on a 84
