GM 12102621, ACD PT308 or an equivalent that you should be able to find at any of the "local" auto part stores. Take the image with you. Had you taken the image to the "locals" that were open today you'd likely have it now!
Many thanks for the reply the problem with that my friend is I'm in England but I have a friend who lives in Nebraska I'll send her the info and picture (fingers crossed she'll get the right part)
That certainly might create an issue I'd guess. I believe now I recognize the "UserID" - Merry Christmas
You might be able to source that connector "locally" even in the UK. I'd maybe check. Is there still Saab outlets?
Not understanding the exchange/postage issues there's many on eBay.UK that maybe you could look at and consider. It's also a knock sensor connector. I saw many possible choices. Some very wild postage quotes!
Perhaps you might check with user "Ray Quayle" He would be someone that you "Need to Know" with your location and a Corvette C4 - Get acquainted:
Now I have a part number to go on I can look eBay uk I'm having a couple of bits shipped over shortly so it was just a small item that could of gone in a box , it's still Christmas Eve atm but thanks anyhow
And I'll send ray a message thanks again
The numbers you gave me is that two part numbers for the same item or one long part number ???
Same part but two numbers first is GM and the second is the AC Delco trade number. Either should work for a search and many/most times the knock sensor application will be found. The CTS if this is an original and you didn't mention year or anything else is generally replaced with a different CTS and a 2 wire connector.
What year, specific application and location on the engine is it?
