crankshaft position sensor help
Old Dec 25, 2013 | 08:30 PM
idprints's Avatar
idprints
Default crankshaft position sensor help
Can the crankshaft position sensor, keep my corvette from starting?
Turns over fine but wont start.
Where is it located please?
Tks everyone
Old Dec 25, 2013 | 08:45 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
You don't have a crankshaft positioner per se, that was on the 96 up. Do You have spark? Fuel? It could be a lot of things, you need to isolate the problem, its awful expensive to try and guess.
Old Dec 25, 2013 | 08:53 PM
WW7's Avatar
WW7
With a problem of the car not starting, the first thing you have to figure out is if it's fuel related or spark related...Then you will know how to proceed....WW
Old Dec 25, 2013 | 09:07 PM
DanielRicany's Avatar
DanielRicany
Yes but your car either uses a pickup coil (L98), or Optispark (LT1). You need to see which one you are not getting, spark or fuel. Then you can go from there.
Old Dec 26, 2013 | 12:33 PM
idprints's Avatar
idprints
iam getting fuel. Spark I don't know whats the best way to check?
Old Dec 26, 2013 | 01:24 PM
DanielRicany
Just pull off a spark plug wire and hold it like half an inch away from the spark plug and have someone crank it over. If you see an electrical arc, you have spark. Then you would be looking at other problems such as timing or compression. Or low fuel pressure or low spark voltage.
Old Dec 27, 2013 | 12:45 AM
vetteoz's Avatar
vetteoz
Read
http://www.mainstreamtopics.com/foru...rt-diagnostic/
Old Dec 27, 2013 | 01:33 PM
idprints's Avatar
idprints
Ive got good spark& strong odor of fuel!
Old Dec 27, 2013 | 03:33 PM
DanielRicany
I would say you have a fuel injector that dumped fuel, or more than one. If you try to start it with your foot on the gas pedal, does it try to fire up?
To crankshaft position sensor help
