Bad Idle
Old Dec 27, 2013 | 08:09 PM
MrPi's Avatar
MrPi
Default Bad Idle
Hello I am very new here(just signed up) I have just recently bought my dad's '85 Corvette from him after my Jeep gave up the ghost.
I have noticed that the park and neutral idle is around 950 after it warms.
It seems like it wants to launch and almost dies while on the brake going from neutral to drive(automatic tranny).
It idles at 650 in drive and in park before the thermostat opens at 195F
I don't know exactly where to start to chase down this problem and looking for a 'cheaper' fix than taking it to a mechanic (poor college kid) plus I want to learn more about the car.
If anyone could point me in a direction it would be much appreciated. Thank You.
Old Dec 27, 2013 | 10:21 PM
Kevova's Avatar
Kevova
was car used regularly or just sat for long periods of time? if it just sat until needed it just may need driven. check air filter, for vacuum leaks, throttle body is not covered with carbon. Is or does check engine light come on?
Old Dec 28, 2013 | 12:44 AM
MrPi's Avatar
MrPi
It was drove every 2 days at least and check engine light comes on every time I drive more than 20 miles Highway speeds 70ish unless I'm hard on it. Recently had transmission rebuilt (2 weeks) before I bought it
Old Dec 28, 2013 | 03:55 AM
Cliff Harris's Avatar
Cliff Harris
Pull the error codes:
http://forums.corvetteforum.com/1574918379-post18.html
http://corvettephotographs.com/c4vettes/codes.htm
What they mean:
http://forums.corvetteforum.com/1576116036-post35.html
They changed over the years, so check the ones that apply to your car.
Old Dec 28, 2013 | 05:15 AM
pastamike's Avatar
pastamike
What they mean:
saw this post before and on pulling codes,on my 1996 c4 i could not find an options button to press on, im i missing something or is info wrong for the 96.
Old Dec 28, 2013 | 06:45 PM
MrPi's Avatar
MrPi
I got code 43 electronic spark control. Would that cause the high idle?
Old Dec 29, 2013 | 02:19 AM
Cliff Harris
No.
ESC is what they call the knock sensor and module. It retards the spark if it senses knocks.
Old Dec 29, 2013 | 11:27 AM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
I would fix that code either way and also check your timing that is what cause my bad idle. I finally re-timed my car yesterday and it is driving and idling better than ever.
Old Dec 31, 2013 | 08:38 PM
MrPi's Avatar
MrPi
Is there a guide on how to do this? Or at least check it?
To Bad Idle
