help with codes please
Old Dec 29, 2013 | 04:29 PM
pastamike's Avatar
pastamike
Default help with codes please
p0400
p0100
p1641
p1661
i know one code is maf, and one is egr, and other two are check eng light not working or something like that. should i just replace the egr and maf, and go from there...car idles poorly and lights and some times seems like it want to stall...any and all help would be great ty..
pastamike..
Old Dec 29, 2013 | 05:15 PM
BstrdC4's Avatar
BstrdC4
1641 is Fan Control Relay.
When your coolant get hot, does your fan turn on?
Get some electronic cleaner and clean the grounds, relay. See if code pops back up. If it does, replace the relay and go from there.
1661 is Malfunction Indicator Lamp (MIL) Control Circuit.
Most likely a bad bulb.
The system sends electricity through the circuit, if there's a bad bulb the electricity can't complete the circuit and the code pops up.
Replace and re-scan.
Old Dec 29, 2013 | 06:13 PM
pastamike's Avatar
pastamike
thanks guess i'll replace maf, and egr, check relay but where would i find the bad bulb. and thanks
pastamike
To help with codes please
