Engine VIN Question on a 94'
Old Jan 2, 2014 | 10:03 PM
67Olds442x2's Avatar
67Olds442x2
Default Engine VIN Question on a 94'
Happen to have parts removed to get at the Opti-spark and figured I'd check engine #. The manual states 1R5XXXXXX. I have V0831WHF. Anyone know what I got? Thanks.
I got it from the pad by the coil.
Old Jan 2, 2014 | 11:20 PM
vetteoz's Avatar
vetteoz
Because your block at least is not from a Vette
The correct block for your year would be coded ZWA , ZWB or ZWC
WHF is listed as a '94 Camaro ( 2 bolt mains ) w/ auto
Old Jan 2, 2014 | 11:30 PM
vetteoz's Avatar
vetteoz
FWIW
Vette and F-Body LT1 engines are identical except the Vette got 4 bolt mains
The lower 275 Hp rating of the F-Body version ( vs 300 Hp ) was because of the more restrictive exhaust used on those cars
Old Jan 3, 2014 | 12:01 AM
67Olds442x2
Thanks. I did find some info "1994 350 275hp TPI F, Auto, Oil cooler, early". Just like you state. Great, now I got a basket case. I do have aluminum heads. The car runs rough and leaks oil, now I know why, it's been messed with. Time to make it better.
Old Jan 3, 2014 | 01:01 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Originally Posted by vetteoz
FWIW
All C4 vette LT1's and L98's are two bolt mains, not that it makes much difference.
Old Jan 3, 2014 | 02:02 AM
vetteoz's Avatar
vetteoz
Originally Posted by zr1fred
All C4 vette LT1's are two bolt mains
Most would beg to differ
http://forums.corvetteforum.com/c4-t...olt-mains.html
http://forums.corvetteforum.com/c4-g...bolt-main.html
http://dave.h-body.org/%2777%20Hatch...nfo%20Page.htm
http://en.wikipedia.org/wiki/GM_LT_engine#LT1
Old Jan 3, 2014 | 06:45 AM
67Olds442x2
Thanks for the info, I need to brush up on the LT1, I'm a big block Olds guy. So basically I got a non-numbers matching car all else being equal sort of. The engine has been replaced, so as I go through any troubleshooting to fix my hesitation problem and rough idling, I just need to keep that in mind. I mentioned basket case only because I have interior issues, window issues and some body issues. My son repainted the car in tech school because the clear coat and paint was peeling and the instructor noticed that the car had been repainted 5 times before. It just makes me wonder.
Old Jan 3, 2014 | 08:09 AM
vetteoz's Avatar
vetteoz
As I noted, the engines are the effectively the same as far as problem solving goes.
There are external differences like the crank hub , front accessory drive and exh manifolds that have ( had) to be fitted in order to use the F-Body block in your car
Old Jan 3, 2014 | 08:10 AM
WVZR-1's Avatar
WVZR-1
I believe I'd be "wondering" also BUT I believe I'd be putting a "mil gauge" to the exterior painted surfaces to confirm the comment "5 times" - since it was done in a tech school environment it would seem to have been a candidate for a proper "strip & refinish".
Old Jan 4, 2014 | 01:59 PM
67Olds442x2
I noticed a sensor between #1 and #3 plug only because there was one wire that was routed to it, not factory routing. Come to find out it is the engine temp sensor. So I guess the heads were installed on opposite sides or maybe on the camaro, which this engine comes from, this is correct.
Old Jan 4, 2014 | 03:28 PM
WVZR-1's Avatar
WVZR-1
I do believe the F-body LT1 does use a temp sender at that location for the gauge/light.
To Engine VIN Question on a 94'
