Center caps
Old Jan 6, 2014 | 09:58 AM
sante65's Avatar
sante65
Default Center caps
I bought center caps for my '93 but for some reason they do not fit on my rims. I thought they were all the same size. The are too small to snap on. We're there different sizes?
Old Jan 6, 2014 | 10:27 AM
c4cruiser's Avatar
c4cruiser
Center caps that are sold by aftermarket companies are usually made to fit aftermarket wheels, not OEM wheels. Did the seller state specifically that the caps would fit OEM wheels?
Old Jan 6, 2014 | 10:51 AM
WVZR-1's Avatar
WVZR-1
Corvette C4 center caps are essentially 2 diameters if were discussing the "hub center bore" caps - '90 and earlier are smaller than the '91+ center caps. Generally the "replica" after-market wheels will use the same as production center caps that they're replicas of.
The '88 - '89 larger style that covered the wheel mounting hardware are of course an exception.
What wheels do you have? Where did you buy your center caps? If you bought what you thought should fit then the cap would have the correct C4 emblem on the face of it, '90 and earlier or '91+. The difference is quite obvious, look at your hood and gas door emblems if you don't know.
Old Jan 6, 2014 | 10:38 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Originally Posted by WVZR-1
Corvette C4 center caps are essentially 2 diameters if were discussing the "hub center bore" caps - '90 and earlier are smaller than the '91+ center caps................. the cap would have the correct C4 emblem on the face of it, '90 and earlier or '91+. The difference is quite obvious, look at your hood and gas door emblems if you don't know.
I stumbled across this also. I have had some '85, '86, 90, 94, and ZR1 wheels and when I tried mixing the caps they didn't work.
The OD of the face of the caps is actually the same, but the OD of the attachment clips on the back side is different. LIke WVZR-1 stated the 91+ are larger diameter on the clips and the C4 emblem is different too.
To Center caps
