Z07 Option?
Same size tires/rims all around.
Larger Sway Bars.
Big Brakes.
Adjustable Suspension.
front spring rate (N/mm): 90.1
rear spring rate (N/mm): 57.2
front wheel rate (N/mm): 29.4
rear wheel rate (N/mm): 33.5
front anti-roll bar diam. (mm): 30 Solid
rear anti-roll bar diam. (mm): 24 Solid
wheels (in*in*mm offset) front: 17x9.5x56
wheels (in*in*mm offset) rear: 17x9.5x56
front tires 275x40ZR17
rear tires 275x40ZR17
shocks : ride adaptive Delco/Bilstein gas shock
front lower bushings: heavy duty, front, lower control arm bushings(ft 13.5k n/mm, rr 3.5k n/mm)
this data courtesy Hip Halverson from http://vettenet.org/susp_chart.html
so it would contain different springs, steering rack, shocks, sway bars
Until something breaks on it... then you'll wish you had the money to fix it.
