Check Engine Light
Old Jan 14, 2014 | 06:36 PM
hdrydr1051's Avatar
hdrydr1051
Default Check Engine Light
My check engine light came on while goosing throttle to get on interstate. Car ran rough and light did not blink. Stayed on. After getting home and restarting engine, light went out. 1985 C4 w/at.
Old Jan 14, 2014 | 08:19 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
You need to find out what the code is, you can do this by stopping by most any auto parts store and they will check it for free or do a search here and see what pins to jump on the ALDL plug to read the code.
http://www.neilkline.com/Tech%20Tips/obdcodes.htm
post 4 has a link to codes
http://forums.corvetteforum.com/c4-g...-a-1985-a.html
Old Jan 15, 2014 | 12:47 AM
Cliff Harris's Avatar
Cliff Harris
Here's a link to a Forum post on error codes for all C4 years:
http://forums.corvetteforum.com/1576116036-post35.html
Old Jan 15, 2014 | 04:55 PM
hdrydr1051's Avatar
hdrydr1051
Default ERR Codes.
Thanks for the info. Much appreciated. I jumped A & B on ALDL and got the following err codes. 13, 33, 34, 43, 44. Could this be an oxygen sensor issue here?
First Corvette and don't want to throw a lot of $s replacing different sensors if not needed. 1985 AT w/54000 mi.
Old Jan 16, 2014 | 12:24 AM
Cliff Harris
Usually if you get a bunch of error codes it's because of bad grounds.
There is one main ground on the engine that everything ECM related goes to. On my car it's above the oil filter on the side of the block. I know in earlier years it was on the back of the driver's side head. I'm not sure if that was '84 only or '84 and '85.
To Check Engine Light
