Gonna be sweeeeet!!!
Old Jan 28, 2014 | 05:25 PM
SoAlVette's Avatar
SoAlVette
Default Gonna be sweeeeet!!!
Major project going on. Dropping my batwing to replace the stock 2.59 dana 36 with a 3.07. While I have it out I am going to replace my bushings with urethane bushings from Prothane. Also going to polish everything up, batwing, all control arms and hubs, exhaust and driveshafts. Replacing main u-joints while I have it apart, had already replaced half shaft u-joints and rear wheel bearings a couple of months ago. Here is a little sampling of what I can look forward to.
Old Jan 28, 2014 | 06:42 PM
84wuzmy1st's Avatar
84wuzmy1st
You are going to love the 3.07!
Old Jan 28, 2014 | 07:03 PM
SoAlVette's Avatar
SoAlVette
Really looking forward to it. From what I have read and heard, should add a nice spring to my 95's step.
Old Jan 28, 2014 | 07:17 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
The 3:07 is a great street gear but if your going to autox take the next step up.
Old Jan 28, 2014 | 07:21 PM
SoAlVette's Avatar
SoAlVette
No racing for me, just like to get on it from time to time
Old Jan 28, 2014 | 07:43 PM
roadcaqpt's Avatar
roadcaqpt
With the gear swap what range will the top end fall into. I need to ck my 95 ratio, it has a good snap to it now.
Old Jan 28, 2014 | 08:21 PM
SoAlVette's Avatar
SoAlVette
If you have a 6 speed, it may already be a 3.07. Mine is automatic, which 2.59 was common stock.
Old Jan 28, 2014 | 09:07 PM
Klyde's Avatar
Klyde
I have a 96' automatic with the 3.07 rear and my top end is 163mph.
Old Jan 28, 2014 | 09:15 PM
l98tpi's Avatar
l98tpi
Max G’s
OP says in original post he has a 2.59 and going to upgrade to the 3.07 which is a very good idea, even for the street. Enjoy the new gear. One other nice upgrade if you haven't done yet would be the 3 piece under drive pulley set.
Old Jan 29, 2014 | 07:03 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Dont forget to add a drain to the differential wile its apart.
Old Jan 29, 2014 | 07:15 AM
Paul Workman's Avatar
Paul Workman
It will reduce it by a factor of = 2.59/3.07 = .844 x top speed for any gear
However!! rear wheel torque will be increased by a factor of 1.185 x current torque in any gear. That will make quite a difference, especially at normal city/highway driving!!
Old Jan 29, 2014 | 11:34 AM
smooth1990's Avatar
smooth1990
What is considered the best stock gear ratio in the C4? I have the 3.54 in my 92.
Old Jan 29, 2014 | 09:00 PM
l98tpi's Avatar
l98tpi
Max G’s
My opinion would be 3.07 for auto and 3.45 for a manual. And, I'm referring to the L98. Higher numerical ratios may work a little better for an Lt1.
Old Jan 29, 2014 | 09:55 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I went from a 3.45 to 3.73 and love it.
OP your rear suspension is going to look great!!
Old Jan 30, 2014 | 10:16 AM
GKK's Avatar
GKK
I've had both the 2.59 and 3.07 gear ratios and the 3.07 really made the L98 feel a lot Peppier!...
Be very cautious, when driving in the rain though...
Old Jan 30, 2014 | 10:42 AM
MRPVette's Avatar
MRPVette
Mine has the 3.07 gear ratio.
Old Feb 3, 2014 | 12:12 AM
17inac4's Avatar
17inac4
Got a link to half shaft u-joints? Going from a 2.59 to a 3.75 in mine.... Can not wait to punch it!! Lol
To Gonna be sweeeeet!!!
Old Feb 3, 2014 | 01:28 AM
mnstrlt1's Avatar
mnstrlt1
I can't believe these c4's came with a 2.59 rear gear. I have 2.73's behind an automatic in another vehicle I own, and it's a dog. I would imagine a 3.07 should be MINIMUM, if not 3.31's and higher. Depending on power level, and the use of the car, I think 3.5x or 3.7x would be great. The overdrive will be more useful, and still provide good MPG (in an auto car).
The LT5 guys are jumping to 3.73's and even 4.10's. Which, behind a 6-speed is very appropriate on the highway and 5th and 6th gear usage. Heck, with the 1st gear in the ZF6, a 4.10 is still fine. "If' you exceed 450rwhp, the 4.10's might feel a bit short in the first few gears, and traction could be a problem.
Old Feb 3, 2014 | 01:30 AM
mnstrlt1's Avatar
mnstrlt1
This is a mystery ratio to me. I've heard about it, but I haven't come across a car actually equipped with them. I think the difference between 3.45's and 3.54's would be MARGINAL at best.
Old Feb 3, 2014 | 07:17 AM
Polo Vert's Avatar
Polo Vert
The 2.59 isn't as bad as you would think. Certainly not like the old cars with a 2.73 or 2.56. The 4L60 is geared pretty good for this gear. While not ideal for the stoplight grand prix the 2.59s pull out pretty decent.
